1996 BLACK GTI W/MK4 NEUSPEED SUPERCHARGER
Was used as a DD for me.
140k miles(purchased 10/2012 with 124k), it is stored in a semi warm garage till she sells. Also has been on a battery tender.
Currently does not run. Car died on a test drive around spring 2017 and hasn't been repaired, suspect a bad fuel pump due to sitting for periods of time. I am located out of state so I have not had time to get it to a repair shop.
List of repairs all performed by VW certified mechanics;
(All parts were new VW oem parts)
Spark plugs(after market)
Spark plug wires(after market)
Timing belt and tensioner
Power steering belt
Both front axle seals
New clutch/rebuilt transmission
Rear Main Oil seal
Distributor cap/Rotor
Passenger front Ball joint
Driver outer CV boot
E-brake Cables
Front main seal(crankshaft)
Crankshaft gasket plus 1 other ring gasket
Rear passenger and driver motor mounts
Used throttle body
Pass front park lamp socket and bulb
Battery (10/2016 replaced)
Oil change w/filter (spring 2017)
Add-ons;
Mk4 2.0 neuspeed supercharger
H&R lowering sport springs
Custom intake that is temporary, never recieved the full intake like I was supposed to w/the SC.
Front racing seats, Party seats in the back.
BFI stage 1 front motor mount(have the other 2 mounts to send with the vehicle, as it was too much vibration for me to have all 3)
Needs New pads and rotors [rotors are warped]
It is currently on my winter wheel setup(pictured) and tires are old and will need 4 new snow tires.
$1500 as it sits and will most likely need to be towed.
Feel free to reply to this thread or email me at 8bitspacekat@gmail.com
Sorry no trades
