Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Olympia, WA
    BMW 228i, VW Cabriolet
    Default Fuel Filter Replacement
    I'm coming up on 40K with my TDI, so I'm about due to for the first service I will pay for/handle myself (first 3 were included with the purchase). Looking back in my records, the dealer didn't change the fuel filter @ 20K, though it is supposed to be done then.
    Do you guys change your fuel filter yourself?
    If you do, do you have the software to prime the system? I have read that you can damage the HPFP without priming it, but then it seems there are plenty (dealers included), that don't even bother.
    I have taken my system apart and not primed it again. I also did not drain the filter housing at all. Just be sure to clean the entire area of sand and dust, not a fun place to make a little mistake.
    Lakeville, MN
    MKVII GSW TDI
    I've changed probably 6 or 7 fuel filters on my two TDI's. I used the VCDS prime method each time and it worked quite well. I have heard of people filling the filter housing with fuel and diesel clean. Either way seems to work, but VW recommends the software method only.
    You should text Kroiss. He put a filter system on his tdi that uses the filter off a bulldozer or some shit. He'll know about bleeding.
    Savage
    BMW X1
    I've done it twice on a friend's car, primed via vag com.
    Wouldn't risk it without priming.
    “We act as though comfort and luxury were the chief requirements of life, when all that we need to make us really happy is something to be enthusiastic about.” Charles Kingsley
    Don't do it without priming the filter with vag com.
    Bloomingtown
    My Saab
    I think I've done about 8 or 9 filter changes and only ever opened it up and swapped out. Never had any issues. The Passat doesn't even idle funny right away. I do try to leave the key to ON for several seconds before turning it over though - no idea if that helps or not.
    Quote Originally Posted by Kriesel View Post
    Why?
    Lakeville, MN
    MKVII GSW TDI
    Quote Originally Posted by Champ View Post
    Why?
    The high pressure fuel pump alone is $650. If it isn't lubricated by the fuel, it shoots metal fragments through the fuel rail, the injectors, to the tank (remember fuel pressure is pretty much constant so the overflow goes back to the fuel tank), back through the lift pump and takes out your whole fuel system. All said an done about $4k worth of parts. Same thing happens if you run gas instead of diesel
    the pump is pretty fragile
    Why?
    This could happen to you:
    HPFP Fun
    The more I've read and learned about this topic, the pump isn't fragile, but if not super clean and lubricated, can easy get destroyed. If properly primed after doing a fuel filter change, the risk of wrecking the pump is non-existent it would seem... So, do it correctly, and prime the system with vagcom, clear out any air in the system, and send filtered fuel into the HPFP after a filter change.
    Olympia, WA
    So should I worry about having run the same filter for 40K? I guess if I keep the car and do the dieselgate fix, it will all be covered until 160K miles, so I imagine any problem would present itself by then.
    Lakeville, MN
    MKVII GSW TDI
    Quote Originally Posted by TTaM View Post
    Where are you at? If you swing by my place in Lakeville we could change the filter in about 20 minutes.
    Lakeville, MN
    MKVII GSW TDI
    double post
    Olympia, WA
    I just spoke to Westside. They agreed, they do not have a filter replacement listed being done on my car anywhere in their system, so they'll replace it for free at 40K. I'll probably just have the dealer take care of it, and figure out what to do @ 60K if I decide to keep the car.
    Hmmm, Im sure mine WAY over due seeing as ive put 50k on and not changed it and I do not know about previous work.
    Lakeville, MN
    MKVII GSW TDI
    you may run into starting issues when it gets cold. I replace mine every October. or roughly 25k miles
  1. WTB: Gauges: Water temp, fuel level, boost, air/fuel (narrow band)
    By Dane in forum VW-Audi Parts Classifieds
    Last Post: 08-23-2013, 07:46 PM
  2. E30 Fuel Filter and Hoses Replacement?
    By alpineE30 in forum Technical
    Last Post: 02-25-2012, 08:32 PM
  3. New fuel pump & filter = No Fuel
    By Crispy222 in forum Technical
    Last Post: 07-14-2011, 08:02 PM
  4. Audi C5 fuel pump replacement
    By JTapper in forum Technical
    Last Post: 02-15-2011, 09:14 AM
  5. BMW E30 fuel pump replacement DIY.
    By 2.5-12 in forum BMW DIY
    Last Post: 10-15-2010, 11:03 PM
