Results 1 to 14 of 14
    Aug 2008
    rosemount
    b6 a4/g-whips/mnstertruck
    Default Anyone know a radon mitigation guy
    So, pretty sure I have at least some amount of radon in the basement and may need to go with a mitigation system of some sort. Does anyone know a guy or have used one they would recommend that would come take a look/test/whatever they need to do?
    '18 Camry, '30 Chevy
    That home inspection company I recommended in the other forum can do radon testing. They have the electronic tester that takes readings every hour for 48 hours for a very accurate test.
    Do not trust any inspectors that use disposable testers.
    And the electronic test will cost you about $150.
    Scheunemann Home Inspections
    651-646-0009
    Ya, what he said on a second opinion.
    Bloomingtown
    My Saab
    http://www.amazon.com/Safety-Siren-S.../dp/B011ACOMK0
    We just had to have a mitigation system installed (last week) into our house as sealing the sump and water main holes only brought the level down to 4.6 (acceptable limit is 4.0).
    We had a business called Healthy Homes install it, they do $1500 no matter what. Took 4 guys 2 hours and they were out of there, now radon is at .5 so that's good I guess.
    The whole thing just seems kinda fishy but if you are buying or selling a home it's the new hot key word.
    Quote Originally Posted by Champ View Post
    I'm with you on that one.
    Yeah mitigation is spendy for what it is. You are basically venting your basement out to fresh air instead of up through your house.
    FYI. The reason I say not to trust the disposable radon testers is because I just sold my house, and the buyer had a radon test done. Not only did the buyers inspector use disposable testers, but he placed them improperly. My house failed, marginally, with a 4.05.
    I disputed the test after I found out it would cost $1500 for mitigation. Had the home inspector recommended above come in with their electronic reader, A larger, more commercial, tester than the one Champ linked to. Their test resulted in a 1.8.
    So a real test, done right, saved me a ton of cash.
    Aug 2008
    rosemount
    ya, I won't be doing any real testing until I seal up what would have probably been an old well room. still dirt floor under my stairs in the basement. until that is fixed there is no way of doing an accurate test
    Well, just because you have open dirt in the basement, doesn't mean you automatically have a radon problem. Yes, radon comes out of the ground, but the contamination varies. So you may not even have a problem when you are all done.
    Aug 2008
    rosemount
    the initial throw away test was double what the "safe" level is, but that was with it pretty close to where the dirt floor room is, thus my initial concerns. I will be filling that room in once its warmer out and then have someone with a quality tester come out. just trying to plan ahead.
    Highland MF'n Park
    Ferd Fercus
    Why not DIY? I have a drill you can borrow if you rent the bit.
    Quote Originally Posted by the_bomber View Post
    The problem with that is you are supposed to use 3 disposable tests placed in different areas to get an average. There are also other rules about making sure they are not anywhere near things that move air, like your furnace, fans, or HVAC vents.
    Putting a floor in that room will help. Radon can penetrate concrete, but as a gas, it will still tend to take the path of least resistance and vent around your house.
    Good luck.
    Aug 2008
    rosemount
    If after I get everything sealed up and its still an issue, I will be doing it myself most likely. I'm cheap.
