Results 1 to 4 of 4
    Jan 2010
    Lincoln Nebraska
    Depends on which day !!
    Default 1987 VW Jetta Turbo diesel ( swapped ) 5 speed - Nebraska
    $3000
    located Lincoln nebraska.
    Consider Mk1 Caddy trades.
    EDIT: March 1st , 2016
    NEW GILES Injection PUMP
    New timing belt / water pump.
    NEW heater core. Installed a nicer dash.
    1987 Vw Jetta turbo diesel ( swapped )
    Think it eco-diesel swap
    Odometer says 147k not sure miles on motor
    ACH 5 speed manual transmission
    Clean Texas car ( been in Nebraska. 3-4 months )
    Recaro trophy seats / matching door panels
    Non-sunroof
    Ac equipped but not swapped over to function
    Great tires on tear drop rims
    Manual Windows
    Aux input aftermarket CD player with upgraded speakers. Noticed amp wiring under driver seat but no amp
    Starts right up and goes.
    fresh new recaro bottom support installed. Seats rides firm.
    Blower motor fuse keeps blowing - probably the resistor i am going to grab one and replace it
    Road noise when going 40mph + front driver front - i can not figure out what it is.
    Friend bought this Texas few months ago. Flew down to buy Miata. Miata was junk ended buying this and drove it back to Nebraska. Been daily since into last week. When I bought it..
    I was gonna toss on some coilovers / lowering suspension , toss in some 15" bbs with newer 195-50-15 tires and see what happens on eBay.
    Before I get there. Thought I'd check mid-west interest.. Glow plug button under steering wheel column and works. Starts right up.
    Only rust spot I found was driver door sill...
    402-671-0355. Text is best
    Located Lincoln Nebraska. In my driveway
    only spot of rust i can find - inside driver front door
    Hood - has a 5 inch circle of discoloration - body is CLEAN - might be original paint even -
    Super clean car - $3000
    located Lincoln Nebraska.
    Vw Enthusiast Garage
    www.volkshole.com
    Jan 2010
    Lincoln Nebraska
    edited the ad. Finally replaced the injection pump with a rebuilt one from Giles , new timing belt , water pump , new heater core - installed a better dash. Fixed the recaro webbing so you don't sink into it.
    I am firm on the price - would consider trade for mk1 Caddy -
    www.volkshole.com
    Sep 2010
    Rabbits, many.
    Did you out another 8mm eco pump on ot or a real TD pump?
    Jan 2010
    Lincoln Nebraska
    Quote Originally Posted by kustomizingkid View Post
    Turbo diesel pump
    www.volkshole.com
  1. Replies: 3
    Last Post: 08-03-2015, 02:54 PM
  2. FS: 1990 Vw Jetta 1.8t swapped 5 speed - Needs TLC - Nebraska
    By vwsnaps in forum VW-Audi Car Classifieds
    Last Post: 06-17-2015, 11:45 PM
  3. Replies: 1
    Last Post: 03-16-2015, 12:19 PM
  4. FS: 1991 VW Jetta Eco-diesel - 1.6 factory turbo - 5 speed - Nebraska
    Last Post: 08-17-2013, 01:26 AM
  5. FT: Trade or for sale: 1990 Jetta Diesel NON TURBO - Nebraska
    Last Post: 05-27-2013, 05:17 PM
