Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Tdi egr del
    Default Tdi egr del
    Yeah, so I'm really not going to deal with cleaning the whole intake thing more than once.
    To that end, I plan to delete the EGR. It seems like since it's basically illegal, kits are hard to find. Has anyone pieced together a kit? Is it really just as easy as a plate?
    This one has a race pipe:
    http://www.ebay.com/itm/VW-TDI-MK4-A...962b84&vxp=mtr
    I found some killer vac line diagrams:
    Anyone have any tips?
    Apr 2010
    Monticello
    2008 Passat Lux Wagon
    With the changeover to ULSD, intake cleaning has almost become a thing of the past. That being said there is a lot of information online about EGR deletes. The racepipe seems to be the most favored.
    Jan 2007
    Farmington, MN
    '85 Porsche 928S
    I did the race pipe and the block off plate. It took like 15 minutes. Ha! I think I got it from ID parts.
    It's all good as long as the balls don't touch.
    Cambridge, MN
    mk4 TDI, TDI Ranger
    Quote Originally Posted by 10001110101 View Post
    ^This.
    If you want to do it anyway, all you need to purchase harware-wise is a couple block off plates (idparts.com) and pick up a hose barb to eliminate the egr cooler. Tune is the biggest expense for the delete but contact Jon for that.
    Unless you want to physically remove everything its a really easy job. Id leave the egr cooler and all the lines, once you pull the ciculation pipe from the cooler to the manifold off (and block them) there is nothing left to gunk you system. Have a tune done and remove the egr cycle. Finished.
    Thanks for the info, I think I read too much on the internet. I like my info from people I "know" vs. some dingus.
    The only reason I want to clean the manifold is because it was last done about 3-4 years ago, as far as I know. I figure it could not hurt...It looked kinda gross when I was looking in the EGR valve the other day. Knowing that stuff is just hanging there unhooked might wind up annoying me, we shall see.
    Planning on a tune in the spring, but there are a few other things I want to button up first.
    Mounds View
    '03 S10 ZR2,'14 Jetta 5M
    I am sure you read this already but your warm up time in the winter will be longer if you do remove the EGR. If I was building my car now vs back when I did it I would keep it on there, since the ULSD makes it easy to keep things clean.
    Nordeast
    T-IDI - M-TDI - TDI
    Quote Originally Posted by isonic View Post
    ^ This is a big reason why I've kept mine. Anything I can do to help my engine warm up quicker in the winter is a plus for me, since I have a short commute.
    One thing to think about: You can add a 'dynamic EGR' feature to your tune, which means that once the engine starts warming up, the EGR no longer comes on. I plan to add this to my next tune. More reading...
    I have a 44 mile one way highway drive @ about 80mph, and that's all this car gets used for, so it's not an issue.
    I'm not super concerned about the warm-up, but thanks for mentioning it. These cars are weird.
    Bloomingtown
    My Saab
    Quote Originally Posted by palmer View Post
    When I drive our TDI to work, on the way home (so it starts off cold) it can take up to 15 miles highway to get up to operating temp. Interesting to watch! At least it blows out good heat before then.
    On the coldest of days even leaving our heated garage it will not come up to temp for the entire drive...
    Yeah, I'll see how it goes. Seems like people block part of the radiator if it's a problem.
    Bloomingtown
    My Saab
    Agree, never played with that because my care level was too low.
    Mounds View
    When it is 0 degrees and below my car will actually lose heat if the blower is on and I am sitting at a stop light.
    damn efficient engines!
    You can use Cardboard to block the radiator, take the grill off and slide a couple pieces down there. I used basement pipe insulation on my golf, I cut it to size and because its designed to wrap around pipes it wrapped nicely around the grill slats.
    South MPLS
    Bike
    VW actually made a "cold weather" grille bra/cover for mk4's, i have one in a package somewhere...
