Page 1 of 3 123 LastLast
Results 1 to 15 of 39
    Default 2009 TDI HPFP Fun
    I had this problem, and worked through it on tdiclub, but thought someone on here might find it interesting.
    Link to tdiclub thread.
    I had a 2Micron filter kit that sat on the shelf for about 9 months or so, and I finally decided to install it. It was for my mother-in-laws 2009 Jetta TDI. The HPFP is known to have failure problems, and the kit is meant to contain the pump's explosion.
    So, I installed the kit, drove the car a bunch, after about 50-100 miles, the car died and would not start. The HPFP head was removed and an obstruction as found in the output check valve. The check valve is used to build pressure before sending fuel to the rail. After the obstruction was removed by flushing, the car was back up and running.
    A few days and approx 200 miles later, the car was sluggish and throwing low pressure codes. The fuel metering valve was inspected and found to be pristine and 100% clean.
    The fuel rail pressure solenoid control valve was removed and inspected to find a small amount of dirt on the very fine filter. Appears normal for a 80k mile car.
    After cleaning this tiny filter, the car still was running sluggishly, having the same low pressure issues, just driving around the neighborhood a little. The rail solenoid filter was removed again and found to be in acceptable condition. It was decided to inspect the internals of the HPFP.
    The cam follower and roller were found to be completely destroyed. The roller was worn beyond 50%, as well as the cam follower itself was actually allowed to touch the cam shaft.
    It's unknown why the pump failed. I suspect my own user error in installing the 2Micron kit, and inducing junk into the fuel system, thus ruining the pump...
    The camshaft was inspected as best as possible in its resting position, showing major wear, gouging and most likely no lobe lift. Once the camshaft can be removed, the full extent of wear will be seen.
    After seeing the destruction of the moving elements inside the pump, it was necessary to search for metal in the system.
    The Cascade (overflow) valve within the pump was removed and inspected. The filter was completely clogged as well as being oddly collapsed.
    The factory fuel filter was now carefully opened and found To have Minimal specs of metal on top of the filter and small amounts of rusty crud in the bottom of the canister. The filter had approx 20-30k miles on it.
    The amount of metal flakes and crud appears to be normal for a filter with this mileage.
    The contents of the 1micron return filter were inspected and found to have enormous amounts of fine metal:
    It's amazing this car ran for approx 200 miles, while the pump was grinding itself to pieces. It softly and safely gave warning signs and allowed the car to continue to run sluggishly, until finally the cam was ground away enough to no longer produce enough lift for suitable pumping action. But the car never died completely.
    The 2microntech kits have appeared to work as designed and contained the problematic metal contamination, preventing it from spreading into the entire fuel system.
    The next steps are to install a new pump, and a new timing belt kit at the same time as well.
    I crudely opened up the 1-micron filter just to see how bad the metal had contaminated it (not looking to go under a microscope, just wanted an idea how bad it got filled with metal). I'm told that the filter element itself is normally white:
    Metal in the bottom of the filter shell (I cut it open further to get a better picture):
    Some various angles of the pump innards:
    42.5 mm:
    36.5 mm:
    42.5mm - 36.5mm = 6mm
    6mm / 2 = 3mm lift on the cam
    (batteries in the caliper were dead...)
    The shaft feels rough while turning by hand inside the pump. But feels pretty tight still.
    New pump, with 2micron kit installed:
    Added a couple of drops of 2-cycle oil inside the HPFP before running.
    Connected the oem filter and 1-micron filter (from the 2Micron kit), as such. Ran the fuel pump in the tank for about 20-30 mins to filter out anything that may be in the system (it's sorta a maze of fuel lines):
    Using a screw-driver stethoscope to listen for fuel flowing through the filters (but first, let me take a selfie):
    Towards the end of running the pump for a while, I added some additive to lube the entire system:
    Reconnect the filter normally. Plumb the splitting block (part of the 2Micron kit) in order to flush it out with diesel, ran the pumps and flushed it out into a bucket for a short time:
    Connected fuel lines to the HPFP, primed like normal, started it right up...
    Drove 15 miles to work this morning, and will continue to drive it pretty heavily over the weekend, and part of next week, before handing it back to the mother-in-law.
    I'll for sure keep it posted as to how it works out in the long run.
    Big thanks to 2Micron for all the help along the way!!!!!!!! Greengeeker and JFettig were also very helpful as well! We all learned a bunch from 2Micron (Andrew), I believe. Thanks again.
    Savage
    BMW X1
    Lol, cam followers
    07 GTI, its slow
    Western WI
    JSW TDI 6MT & 2 Suburbans
    Ouch!
    Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
    Jesus
    How many miles?
    In the end you figure the culprit was dirt getting in during the install of the first 2micron filter? I know these have a tendency to fail much like the HPFP on the 2.0fsi motors from under oiling.
    Savage
    BMW X1
    i know these have a tendency to fail much like the hpfp on the 2.0fsi motors from poor design and cheap materials.
    ftfy
    Jun 2009
    Jessica, Michelle , Gert
    Are the 2010s having the same issues as the 2009s? Isn't there a change of some sort?
    Dustin-me, Gert- 77 f250, Michelle- ​URs6 Avant, Jessica-caddy
    Quote Originally Posted by McAdam View Post
    There is probably more hot air coming out of your mouth than that engine.
    How many miles?
    The car has 80k miles. I think the culprit was user induced, yeah. Either I did something wrong, or likely didn't clean the filter kit well enough. It sat on my garage shelf, in a box, for about a year before I installed it, and I likely missed crud somewhere, so that's likely what the problem was.
    I've now driven about 200 miles since re-installing the new pump.
    Quote Originally Posted by igotacaddy View Post
    I think there have been reported problems on 2011, but for sure some in 2010 vehicles.
    Supposedly the pumps were made in a few different places, with the crap pumps (the one that broke in this car) made in one country, and better pumps (which I was able to acquire for the new pump) made in another country. Slight differences in the two pumps, but who knows. I guess that if you have a HPFP made in Czech Republic, it's the better version.
    I'm not the expert, so please don't quote me haha
    Just picked up my CR TDI, looking to do some of these protective things aspa. The 2Micron kit is a good buy, yeah?
    If you can get your hands on the 2Micron kit, it's worth it I think... Mention you know greengeeker, jfettig, and myself and maybe he'll help you out a little more haha
    I have the 2Micron kit on my mother-in-laws CR.
    Touareg. XC70. F430.
    Bet your mother in law doesn't let you work on her car anymore.
    Bet she does... But, to that point, no I will not be opening up my garage to work on common rail fuel systems...
    She just drove it to the dakotas and back. Still no issues.
    I contacted 2Micron and the wait list is pretty long for the pureflow High pressure protection piece, I will be getting the filter piece itself soon as he has some of those to send out now. The filter is just the end piece for the low pressure side but any protection is better than no protection?
    East Bethel, MN
    72 911T, '12 Jetta, Tahoe
    Quote Originally Posted by MisdemeanorMatt View Post
    Lol, cam followers
    seriously. that cam is so sad and pathetic to look at. what a nightmare.
  1. cam follower/camshaft/HPFP Warrenty extention....
    By bailey611 in forum Euro Automotive Discussion
    Last Post: 05-18-2011, 12:04 AM
  2. 2009 a4
    By Chaseme in forum Euro Automotive Discussion
    Last Post: 09-04-2008, 02:33 PM
  3. 2009 rs6
    By DougEFresh in forum Euro Automotive Discussion
    Last Post: 08-12-2008, 10:46 PM
  4. 2009 gti?
    By daveninefive in forum Euro Automotive Discussion
    Last Post: 07-22-2008, 04:13 PM
