Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 39
  1. #16
    I contacted 2Micron and the wait list is pretty long for the pureflow High pressure protection piece, I will be getting the filter piece itself soon as he has some of those to send out now. The filter is just the end piece for the low pressure side but any protection is better than no protection?
    Yeah, the filter is just in line with return flow to the tank.
    The other piece separates the high and low pressure sides of the pump.
  2. #17
    05 GTI
    Sad to say, but this is all to common. VW is providing warranty assistance on a case by case basis.
  3. #18
    I may have just had an HPFP failure. Tonight I went out to my used to be perfectly running JSW and it would not start. Cranked and failed. I figured maybe it was just a rough start due to the temp and maybe the GP hadnt fired long enough. Give it another shot and it turns over and starts on the 3rd-ish crank, runs aobut 5 seconds and starts to stumble and fail. 3rd start attempt and it barely turns over, like 3-4 revs and it starts to sound like the battery has no power. Its late, dark and cold so I left it. Ill hike over in the am and stare at it for a while to see what I can see. Im hoping it was a fluke and nothing major but thats just the optimist in me. Im betting a call to westside may be in order.
  4. #19
    Feb 2010
    Saint Cloud
    Changes more than Scotty
    Iiiiiiiish. Sorry about your potential loss.
    How many miles on your car so far? We are at 54k, but are selling to be back with a van again...
    2009 Honda Fit Sport Manual, 71k
    1999 Toyota Land Cruiser of WOW, 241k
    No Euro.
  5. #20
    92k. It isnt for sure yet, could also be the inter
    cooler icing issue as well. Going to check now
  6. #21
    I have a few steps you can check to tell if the pump did fail.
    Remove the fuel metering valve, two screws hold it on (the black capped piece on top of the pump). Religiously clean the area first with brake cleaner or something. Take the two screws out (torx), and pull straight up:
    The end of the metering valve looks like this when you remove it (this is a clean metering valve pictured):
    If that screen is coated in fine metal powder/particles, you failed a pump...
    Also look inside the hole, and look there for metal (this pic has no metal in it):
    Also you could pull the fuel filter and check for metal. If you have metal in either of these places, likely pump failure.
    If the pump failed, bring it to the dealer. Heard good stories of dealers replacing pumps, even if it's out of warranty.
  7. #22
    good news, looks clean.
  8. #23
    That's a good sign.
    Now, why isn't it starting... haha
  9. #24
    Mounds View
    '03 S10 ZR2,'14 Jetta 5M
    I don't know the CR diesels as well, so maybe this is a stupid question; but do they also have an electronic lift pump in the tank? If so, do we know if that is working?
  10. #25
    Cambridge, MN
    mk4 TDI, TDI Ranger
    Stu - do you have vcds? You can run an output test on both in-tank pump and your aux pump to rule them out. To rule out the iced intake simply disconnect it at the front of the motor and start.
  11. #26
    tiny amount of "silver" on the top of the filter element. No more to be seen in the housing or the metering valve hole.
    I will be doing some Vag Com testing tonight but wont get to it until after 830.... I pulled the lower IC pipe and got about a tablespoon of water to fall out, not a whole lot there, doesnt mean I didnt suck a bunch up before.
    A quick vid with a no start. Birds in the background making noise, not all that is coming from the engine
  12. #27
    Cambridge, MN
    mk4 TDI, TDI Ranger
    hmm. I don't HEAR that much compression. Is it smoking while cranking? Do you hear the in-tank and aux pump running when you cycle the key or during cranking?
  13. #28
    The metal on the filter isn't a big deal I don't think.
    When the pump fails, it's a LOT of metal:
  14. #29
    Yeah, all my fears of hpfp failure have passed. I am worried about hydrolock and bent valves at this point. Greengeeker, low compression could mean valve damage or no air entering the engine, yeah? I do not have the tools to perform a compression test
  15. #30
    Cambridge, MN
    mk4 TDI, TDI Ranger
    No, low compression would mean bent rods. Air enters engine but pistons don't come up high enough to give enough compression to ignite fuel when it is injected. Get it charged up and crank for a while. If you have low compression and it is injecting fuel then you'll smoke yourself out of that parking garage.
  1. cam follower/camshaft/HPFP Warrenty extention....
    By bailey611 in forum Euro Automotive Discussion
    Last Post: 05-18-2011, 12:04 AM
  2. 2009 a4
    By Chaseme in forum Euro Automotive Discussion
    Last Post: 09-04-2008, 02:33 PM
  3. 2009 rs6
    By DougEFresh in forum Euro Automotive Discussion
    Last Post: 08-12-2008, 10:46 PM
  4. 2009 gti?
    By daveninefive in forum Euro Automotive Discussion
    Last Post: 07-22-2008, 04:13 PM
