Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Thread: Additives...
  1. #16
    Ditto on the power service... Silver bottle in summer, white bottle in winter... blah blah
    The only problem is getting it into the car, you'll either need a small funnel, or find another bottle to put the additive in that can transfer easily. Something like this:
    http://www.ourplastics.com/twin-neck-bottle/
    I got a similar one at Mills...
  2. #17
    East Bethel, MN
    72 911T, '12 Jetta, Tahoe
    pffff its a diesel, just spill it down the side of the car.
  3. #18
    Mounds View
    '03 S10 ZR2,'14 Jetta 5M
    Palmer, it is good that you are using additives. Just don't get paranoid if you forget to use it one time or something. I have never used any additives in my car, even in the winter. I fill up at good stations and have not had an issue.
  4. #19
    Bloomingtown
    My Saab
    Quote Originally Posted by isonic View Post
    Yes I tried to get that point across with my Jetta but you said it better. We have almost 150k on it and the only thing that has been in the filler is the pump nozzle.
  5. #20
    Minot, ND
    97GTI VR6
    Howes Diesel additive.
    Use in my F250 7.3L power stroke. no issues.
    ........ \______
    ......../__|___ \___
    ........\'o)i___l_(o);
  6. #21
    Thanks guys. I figure my car can only benefit from an additive at this point, and I'm only into it for $20 so far. Figure it's worth it. The $8 I spent on MAF cleaner was well worth it, that's for sure.
    So I found that the Holiday that's on Old Shak and Normandale has diesel, AND the nice lady driving a fed-ex truck I talked to said it was a popular stop for them because it was near a large hub and on shortcut over to 35north when 169 is backed up. I feel pretty alright about volume out of there, so I'll just plan to go there instead of the one near my house. Should be easy.
    Good tip on the dispenser, I need to track that down. The shot glass and funnel I used are not going to cut it on a "regular" basis.
  7. #22
    Western WI
    JSW TDI 6MT & 2 Suburbans
    Just get one of the fuel nozzle adapters to make it easier to pour in your additives. It's a handy item to have when you find a fuel station that only has the big-rig nozzles.
    Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
  8. #23
    Lakeville, MN
    MKVII GSW TDI
    Quote Originally Posted by mimalmo View Post
    This is one of the more annoying things about 2013+ VW's. They have a fuel neck restrictor that won't take either the small gas nozzle or the high flow big rig nozzle. They only take the passenger car diesel nozzle.
  9. #24
    Quote Originally Posted by palmer View Post
    Just be warned, this does not work (at least not in my VW, a truck is likely easier to put additive in):
    This does work:
    Or use option one with a screw on adapter:
    or a sealable funnel:
  10. #25
    East Bethel, MN
    I was going to bitch that you guys are ridiculous but then I realized that all the diesels I've driven are old school, and just have a huge hole to dump stuff in.
  11. #26
    Cambridge, MN
    mk4 TDI, TDI Ranger
    I'll be driving it 3-4 days a week I think, will not be in the garage. No heater either. I'll have to see about getting something going as far as that goes. I swear the PO had one of those coolant based heaters around or something.
    I highly recommend a frostheater given your description of use.
    I've been driving my TDI for almost 10years and 200k miles. Never put a drop of additive in it and never had a gelling issue.
  12. #27
    Feb 2010
    Saint Cloud
    Changes more than Scotty
    OK, so I probably am being paranoid, but the temp WILL drop to lows in the 20's next week and I am about to fill up the wagon. Do I have to worry about gelling or will I be good to go with whatever comes out of the pump at our Holiday?
    Again, new to diesel and don't want to mess up ours... Wait, what is the worst that can happen? Does a gelling fuel just prevent the engine from starting in cold temps or are more major implications possible?
    2009 Honda Fit Sport Manual, 71k
    1999 Toyota Land Cruiser of WOW, 241k
    No Euro.
  13. #28
    Western WI
    Winter blend diesel is already in gas station's tanks. Pick up a white bottle of the Power Service diesel additive if you're worried about it (about $14 for a big bottle at Fleet Farm). Also, it needs to be MUCH colder than this to gel.
  14. #29
    Bloomingtown
    My Saab
    Quote Originally Posted by natehack5 View Post
    Unless you are going to fill it right now then let it sit for 3 months I wouldn't worry.
    The gas stations are always ahead of the cold curve - especially if you buy from any larger/name brand station that goes through it's diesel regularly.
