Page 55 of 57 FirstFirst ... 54551525354555657 LastLast
Results 811 to 825 of 850
Thread: Jeep/Trukwerks
  1. #811
    E39 & E91
    Quote Originally Posted by palmer View Post
    ^yours looks awesome!
    I can change the torsion bars in front, but everyone says it rides (even more) like shit if you raise it up.
    All I want is to clear 33" tires, and have it sit level.
    You should sniff our some of these wheels (barring finding a set of those sweet alcoas that the level 2 came with...)
    I wish they had a wheel that style for the F150. I really dislike the 5 spoke FX4 F150 wheels that I have.
  2. #812
    Yeah, the FX4 wheels of that vintage are oogly.
    I like the ones you posted though! They would look good with darker centers and silver edges on the spokes if that makes sense.
  3. #813
    337, Scirocco, GT, Ranger
    I'll be picking these up on Saturday. 18" Mustang wheels. I'll need .5 - 1" spacers, but those are cheap for this bolt pattern. The tires are actually a quarter inch larger diameter than what are on the truck now. And the truck actually weighs about 400-600lbs less than the 2012 Mustang they came off, lol.
    Now is where I politely tell you to go fuck yourself.
  4. #814
    Mustang take-offs are cheaper than a new set of tires, which is nice.
  5. #815
    That's going to look great!
  6. #816
    Minnetonka, MN
    E30 M3
    Quote Originally Posted by JUSTION337 View Post
    So no Style 5's? I think the Mustangs are a good choice.
  7. #817
    Bloomingtown
    My Saab
    It took quite a bit longer than I expected. I'm not too surprised though considering it was all new to me. It would probably take half the time if I did it again.
    - Every DIY job ever
  8. #818
    Quote Originally Posted by aaronmjr View Post
    I went from style 5s to Porsche Twists to these, because lazy, lol. Want to buy some style 5s for the M3?
  9. #819
    Before cleaning:
    After:
    Back side after:
  10. #820
    Finally! 32mm spacers put them at 12mm now, 2mm less than stock.
    Turned the steering wheel a bit when the engine wasn't running while doing a tape measure alignment and this was left on the shop floor. I degreased and pressure washed the rack and fittings, so I can see exactly where it's leaking, but I'll probably just replace the rack, tie rods, and pump. I can get remanned​parts for around $200 so I think I'll just do it and get it over with.
  11. #821
    Stacy
    Audi 200 quattro Avant
    Looks great! What did all the suspension stuff run you?
  12. #822
    My p/s return line was leaking pretty bad when I got mine, it was a super easy swap.
    What's not so easy is getting all the air out of they system after. First time I went around a corner the wheels shook all over the place and I almost shit myself.
  13. #823
    Quote Originally Posted by Audiphile View Post
    The full suspension kit with poly leaf spring bushings was about $780 shipped, the wheels with tires(@9/32) were $500 on CL, and the spacers were $85 with Prime shipping on Amazon.
    I'll be inspecting it in a bit to see exactly where it's leaking. My pump is grinding pretty good so that will most definitely need replacing. The p.o. put power steering fluid in it instead of the Mercon ATF it requires shortening its life. If you turn the wheel without the engine running, you get the crazy shudder. They say you're supposed to run it with the front jacked up and turn the wheel from lock to lock until it's bled. I just swerved back and forth across the back road by my shop and did a few full-lock figure eights.
  14. #824
    Oct 2014
    Saint Cloud, MN
    '98 Jetta, '91 Jetta
    Oh dang those wheels look even better than I expected on it
  15. #825
    blaine
    hood scoop
    Yeah, those look good.
    bitch, you trippin'
  1. my other vw is a jeep?
    By huck731 in forum Project Forum
    Last Post: 01-19-2013, 10:18 PM
  2. FS: Jeep YJ Parts
    By Kriesel in forum Car Parts Classifieds
    Last Post: 03-15-2012, 11:42 AM
