Page 3 of 14 FirstFirst 123456713 ... LastLast
Results 31 to 45 of 197
  1. #31
    Mounds View
    '03 S10 ZR2,'14 Jetta 5M
    Starting to collect parts:
  2. #32
    Duluth
    Bus, Bike & c5
    Awwww yeah
    Listen twice as much as you talk.
  3. #33
    What brake upgrade are you doing?
  4. #34
    337, Scirocco, GT, Ranger
    Is that Tim's old suspension/brakes?
    Now is where I politely tell you to go fuck yourself.
  5. #35
    Mounds View
    Yes, it is Tim's old stuff. 288mm front brakes along with R32 bushings in the control arms. My suspension is in ok shape but it is starting to wear out. I am also on the hunt for coilovers. When I install the front brakes, control arms and coilovers I will also put in new rear wheel bearings as they are starting to howl a bit. I also picked this up:
    Got some plans to improve the air flow in this engine. More air will lead to more fuel capabilities in the future
  6. #36
    Mounds View
    I have most of the parts needed to make a 2.5" turbo inlet pipe. Waiting on one 2.5" to 2.25" 90 degree elbow that will connect the TIP to the inlet of the turbo.
    Ordered up one 2.25" to 2" straight adapter that will connect the upper intercooler piping to the outlet of the intercooler. Once that arrives I will be able to make the upper intercooler piping with Jon's help since he volunteered to weld for me
    And apparently the snow we got last Tuesday contained alot of water. I found my car in this lake after work.
  7. #37
    Mounds View
    I have updates and pictures. I'll post them later and show off more of Jon's welding.
  8. #38
    Mounds View
    So I got some work done on the charge piping. As every one knows, the stock piping for this car is just lame. The pancake pipe is very restrictive, the side mount inter cooler is prone to heat soak, and the upper inter cooler pipe isn't terrible but it could use some improvement. Throw in a larger turbo and we just compound the issues.
    To increase air flow coming out of the turbo I added the 1.8T pancake pipe and larger silicone on the turbo outlet.
    Then while buying some Recaros from another EW member I picked up a Eurojet Side Mount Intercooler. As you can see it is slightly larger!
    Mounting the SMIC wasn't difficult but it was tedious, like most IC installs it required lots of bumper on/off action. To help fit up the stock plastic air duct Jon welded some posts to the IC for me:
    Here is what it looked like when installed:
    Most of the trimming occurred on the rubber flap that pushes up against the bumper just behind the right bumper grill insert. Moving on to the upper IC piping. A 2.25" to 2" straight was used to exit the IC and connect the piping. Jon welded up this 2" dia. Aluminum pipe for me.
    As it connects to the IC-Sorry a little hard to see:
    Then headed towards the intake:
    I used the stock 90 elbow to connect the pipe to the intake. I did have to trim the elbow where it connects to the intake and make it shorter. By shortening it just slightly it pulled the pipe away from the power steering pump enough to get it to stop rattling .
    Over all this is what it looks like:
    Next I'll show how we did the Turbo Inlet Pipe.
  9. #39
    Oct 2008
    St Paul, MN
    02 4motion Jetta VRT
    Looking good paul!
  10. #40
    Super jealous, I want to do everything youre doing.
  11. #41
    Aug 2009
    Richfield
    03 TDIjettaWgn/03 GolfTDI
    Ditto. Lookin great Paul! I definitely want to do IC piping on mine. I also just realized that I have no air duct on my IC.
  12. #42
    Mounds View
    Quote Originally Posted by joey944 View Post
    I would imagine the air duct is easy enough to come by. Just need to find someone who did an FMIC and snatch up their old one. Or if you are handy with fiber glass maybe you could make one? Sheet metal?
    Also since Jon doesn't have enough to do right now I'll make mention of this: he was thinking about using my car as a templete and making two or three more upper intercooler pipes. If there was enough interest from people who wanted them you could all probably talk him into doing it
  13. #43
    When I get my Malone Tune this month Im going to mention you advertised that!
    But seriously, I will be doing a VNT 17 and GTI pancake pipe very soon. Hopefully Jon will be able to help out, his work looks amazing.
  14. #44
    B5 Passat TDI, 951
    lol thanks Paul! I just used the last of those 4 pieces of mandrel bends. I'll have to get a few more I guess
    Malone Tuning Dealer
    VW/Audi/CRD Gas and TDI tuning including DSG tuning.
  15. #45
    Mounds View
    What nozzles and clutch are you going to run with that?
  1. What was the story with this car?
    By 20V'er in forum Euro Automotive Discussion
    Last Post: 06-01-2008, 10:17 AM
  2. My F40 story of the day
    By CaRJoE0220 in forum Euro Automotive Discussion
    Last Post: 01-08-2008, 10:02 PM
