Are those kris' old wheels?
Today, Pete helped me install a 272º cam in the GTI and then moved the 268º from the GTI into das SPORTRUCK! Thanks Pete!
We finished the GTI, but not the SPORTRUCK. There was a TechtonicsTuning adjustable cam gear on the OEM 2.0L cam shaft, and I do not wan't to keep it. So, I do need now a standard 2.0L cam gear. I believe the car that Ryan (20v'er) is parting out late this week will be a good donor for me
ALSO, just arrived a 120mph GTI speedometer cluster. Going to see if I can adjust the mileage to be more accurate to the actual mileage. Then I might paint the needles like in the GTI, which looks awesome.
Hey John I assume that truck is a gasser? I need a fuel line from a gasser. 99% of the lines turn to dust when they are touched.
i too have extra cam gears, so if anything falls through. the duluth parts-mobile will be in town the weekend of the 28th. sounds like things are coming together nicely.
-Pete flickr
Glad to help, Matthew! Too bad we did not finish her off.
we only ran out of parts![]()
Very true.
I am SO happy I now know how to time an engine.
ditto that! I got some good ol learnin
Hope you blow any shockzzz.
One thing I don't like about the drop plates is it moves the wheel up on the axle. Which means the tire is closer to rubbing on the body. Not that big a deal most of the time, but with the toolbox, I bet it would have rubbed and the axle would still have been inches from the bumpstop.
VWjerm should figure out a way to make an extended bumpstop, so the bumpstop hits before the tire.
