Results 1 to 8 of 8
    2011 Golf Variant SE 2.5
    Default 1.8T oil leak.....
    2003 Jetta 1.8T keeps leaking oil!
    Noticed oil on the garage floor starting a few months ago.
    Checked everything out and the front camshaft seal was leaking a bit. Replaced valve cover gaskets, both camshaft seals, and the cam tensioner seal.
    Oil leak went away for a few weeks. Noticed oil on the garage floor again. Checked everything out and the front camshaft seal was leaking. Replaced it again.
    Seemed find for a couple weeks and yesterday I noticed more oil on the garage floor. WTF
    Just checked and there is oil again behind the cam position sensor. WTF!!!!
    Is there a trick to installing that cam seal or what??? Once I removed the cam cap when I installed the seal, the other time I pressed it in. Both times they leaked so obviously I'm missing something. Am I supposed to use sealant on there or what?
    Thanks, Shawn
    Apr 2007
    Lauderdale, MN
    lolvo
    VWs don't leak, they mark their territory.
    (sorry, no real help here)
    Let me guess, profuse masturbating?
    Farmington
    91 GTI VR6SC, MK6 GolfTDI
    A little sealant wouldn't hurt. I always throw some on when installing a gasket or seal, as long as it is between non moving parts.
    West Minnetonka
    My 1.8t leaks like it has a medical condition.
    Are your air dams in place? At least those would keep the oil off the floor...LOL
    Nov 2005
    St micheal, Mn
    1999 Audi A4 Wagon
    What type of seal are you using?
    Chad Erickson
    SCI Performance
    612-722-8897
    Chad@sciperformance.com
    http://www.eurowerks.org/image.php?u=316&type=sigpic&dateline=1195628404
    Just the dealer seals. Last time I was there I asked them if there were 2 variations (seen mention of them in Bentley) and they said no.
    Is there a "good" one to use?
    And whats up with PCV blockage on the 1.8Ts? How do you check that and what can you do about it?
    Audi A8, A4
    Try some thread sealer on 6mm bolts that hold the CPS in place.
  1. Replies: 1
    Last Post: 03-13-2008, 12:48 PM
  2. B7 A4 2.0T: Oil Change / Snub Mount Install
    By John2.0T in forum Volkswagen/Audi DIY
    Last Post: 02-09-2008, 10:53 AM
  3. oil leak suggestions please?
    By duluthmkII in forum Technical
    Last Post: 02-03-2008, 04:10 PM
