So I got to doin the head gasket the other day and I brought the head in to have it cleaned up and resurfaced. Turns out a few of my intake valves are not seating correctly. Shop said that they could only get a vacuum of 10psi on one of them and it should be 20-25psi. So they are recommending a rebuild, which will potentially cost me $50 for the resurface, $180 for the rebuild and then on top of that $10 for any valve guides that it would need. So the that is potentially $390 for a rebuild with all new guides, plus the price of seals.
So now I am looking for something one of you might have lying around that has had a recent rebuild. I don't want to deal with anything that has high miles with never being rebuilt. So if you have anything let me know.
Thanks
There are a couple things you have to swtich around to use the 1.8 head on the 2.0, you'd have to look it up on the 'tex. Good luck
