Results 1 to 9 of 9
    Default Handling Tuning....
    My car handles great...super great. It just gets really bouncy on bumps and uneven roads...I also notice that when I REALLY push a corner the car starts to skip... Is it too bad for me? Is the suspension TOO stiff? Do I have too many stress bars and sway bars? Tire pressure? I\'d rather have the car predictably understeer a bit than have it skipping down the road....
    suspension thus far:
    bilstein struts (old, maybe bad...? they don\'t FEEL bad if you push on the car)
    neuspeed sport springs...
    4point front subframe from scirocco
    neuspeed front sway
    eurosport upper bar
    eurosport 3 pt rear strut bar
    neuspeed rear sway bar
    Falken Azenis...near new.
    855 Turbo x2
    Default Re:Handling Tuning....
    first... your struts are fine, they are not bad, so get that out of your head once and for all...
    second... if you want a more plush ride you\'ll have to water down your suspension, lower spring rates, maybe shocks that are less stiff, both of which will make the car less fun.
    third... you could always get a set of fully adjustable coils, ride height and dampening, and sell me your suspension in the spring for 3 dollars
    Nobody sits like this rock sits. You rock, rock. The rock just sits and is. You show us how to just sit here and that's what we need.
    855 Turbo x2
    also... you have Falken Zeix, not Azenis.
    sorry....
    found the problem. My front right shock is blown. It\'s sitting on the bumpstop.....I thought it had been going for awhile...its just been getting progressively worse. Now its toast
    855 Turbo x2
    it didn\'t feel blown when I was driving it... sitting on the bump stop? have any pictures?
    no, think an inch and a half lower than it normally is...if you had driven it as regularly as I had, you\'d have noticed the decline...
    855 Turbo x2
    if it\'s sitting lower in that corner it would be the spring, not the strut. The strut does nothing to hold the car up. The spring holds the car up, how does the spring look? any rust?
    Not sure, havent gotten it off yet... I cant just replace one spring... F.... I wanted to get new suspension, just not RIGHT NOW...:unsure:
    the strut must have been bound up...when we jacked it up it didnt even budge... it stayed compressed. put the stock suspension back on.... now I need to afford new suspension :angry:
