Originally Posted by
possebmxer
I am trying to sort out a mess of a 1.8 16v swap the previous owner thought he could cut the connectors off the 16v harness and connect them to the 8v harness
So my question is i have an intact 2.0 16v harness and ecu can i adapt that harness to run the 1.8 16v and i will be swapping manifolds and fuel dist is there anything else i will have to use to swap to the motronic setup
I think you'll need a motronic fuel distributor, throttle body and ISV setup. if the motor if from a scirocco you'll need a 2.0 intake manifold as well. thats all i can think of off the top of my head.
