Yep that's fricken cool.
Hot
20psi + Functional air to water IC = 308whp/290wtq
26psi = ??
BF! built - Revo Tuned
FYI these are the manifolds for the 9000.
$500 as well.
The 9-3/ng900 ones will be of similar design.
how does this differ from the other saab one you made?
The header shown in this thread is for a saab 9000.
The 9000 uses a "normal" transverse FWD setup...
The engine in the C900 runs front to back, and it's FWD as well, so it's a very different header setup. If you were to run a pipe straight out of the header of a C900, the exhaust would run out the grille on the front of the car.
900:
9000:
cool![]()
