Results 1 to 14 of 14
    Champlin
    Anaslex
    Default Volvo V70 misfire. Have any ideas?
    Ok so a friend of mine just picked up a 2000 V70 non turbo for very cheap. I looked at it for a couple minutes on his way home and like the dealer stated, it does have a miss. blah blah. I ran my scanner and (didn't write it down, going off memory) it had 5 codes.. Two random misfires, a couple for the evap or something.. think one was a no voltage, and one was a no flow or something along the lines of that, will have him rescan it today, one that just said Vovlo + 5v?????
    I am going to help guide him get this thing going good, and thought I would ask for your help.
    I am fairly certain it is vacuum leaks etc. or a faulty valve in there. any more ideas would be appreciated.
    thanks.
    If there was an evap no flow code, the vaccum line from the evap solenoid to the manifold could be shot. I'd start by checking all the vacuum lines, replacing anything suspect. I'd throw new plugs in there too since you don't know when they were done last.
    Champlin
    Anaslex
    We did do new plugs and coil packs with no success, vacuum lines is what I am hoping as he is just a high school kid that can't afford to be dumping a bunch of money into it. I hate how they route these damn things though. gotta pull the intake manifold off to get to the solenoid... boo (I have a feeling if I ever have to work on my wifes T6 I will be wishing it was this V70 haha
    Champlin
    Anaslex
    this here is what I suspect
    Crankcase Ventilation System Failure (PCV/Flame trap)
    All 1993-2000 850, S70, C70 and V70 models (as well as most 2001 2007 S60, S80, V70 and XC 90 models) use a complicated crankcase vent system to prevent the build u of pressure inside the engine. Since the mid 70’s Volvo owners have had problems with this system clogging up with oil deposits. Once the system plugs up, crankcase pressure builds high enough to cause oil to be forced past engine seals resulting in oil leaks around the engine. Another problem with this system is the many small vacuum lines used become brittle and crack, rendering the system inoperable as well as causing idle and drivability issues. Since the lines are buried under the intake manifold, it’s difficult to diagnose. To keep the system operating properly it’s a good idea to visually inspect the lines every other oil change and completely replace all the associated components every 80-100,000 miles. We’ve put together handy kits that make it easy to order the correct parts.
    Quote Originally Posted by WhiteRob View Post
    This. The T6 kind of sucks to work on. if you have to do something with the turbos
    It's worth grabbing a piece of vaccum line, and with the engine idling, put one end in your ear and probe around the bay with the other. I'd concentrate on the front of the engine, especially under the intake manifold, as well as on the drivers side of the bay, as that's where the EVAP lines are.
    Rochester
    04 jetta wagon, 12 Golf T
    Check compression on the misfire cylinder. Bet it's low
    Champlin
    Anaslex
    Quote Originally Posted by veedubmechanic View Post
    That was the original plan, but when he went to start it last friday and drive it over, the battery is dead.. I guess that will be this Fridays plan now.
    Champlin
    Anaslex
    OK so after some more research, thinking maybe ETM?!? http://vexedvolvo.org/
    anyone know who (besides a dealer) I could have him bring his car to so he can get the ecu updated?
    ETM causes all sorts of other issues, not just a misfire.
    Did you check for vacuum leaks?
    Champlin
    Anaslex
    That will be the first thing I do is take your advice and check for vaccum leaks, but I won't have access to the car until Friday afternoon. (the kid lives in north branch). I am really only doing this as I love taking on projects, and I get to help out a good kid.
    Rochester
    throttle position sensor wont cause a single cylinder misfire.
    random mis yea, but not a single cylinder.
    Also older 5cyl have lots of issues with the coil pack harness' cracking and causing misfires. But they probably would have crumbled when you replaced the coils.
    Champlin
    Anaslex
    Very good to know. one more day until I get to check it out. I will try the tube in the ear trick, or was thinking of smoke testing it. (good old fog machine) but putting tube in my ear and listening around is quicker. Would a stethoscope work you think? I am an amateur gynecologist so I have doctor toys.
    Rochester
    light a ciggarette, take the evap hose off, blow smoke in, find leak
    Champlin
    Anaslex
    Damn, looks like I have to start smoking again.. well its an excuse to buy a pack of cigs anyways haha
  1. Very frustrating Misfire
    By Tricks in forum Technical
    Last Post: 05-10-2010, 09:58 PM
  2. Saab CEl -Misfire Code#P1304- any ideas?
    By Conman in forum Technical
    Last Post: 01-29-2010, 07:48 AM
  3. Misfire VR6
    By eurotrash in forum Technical
    Last Post: 11-16-2009, 05:48 PM
  4. Replies: 2
    Last Post: 10-23-2009, 01:29 PM
  5. Sporadic Misfire
    By ScottP in forum Technical
    Last Post: 08-19-2007, 11:36 PM
