Its time for me to move on to my next project.
Details:
2005 VW GTI
65k
Exterior:
1. Ottinger full body kit.
2. R32 rear wing.
3. HID headlights. (6000k)
4. 35% tint up front and 20% on the rear.
5. 17" Ariettas painted with 94 vw corrado purple.
6. 10mm Spacers front, BAS spacers in the rear (Big ass spacers... 40mm or something crazy)
7. Also have 17" Montes with winters
8. Have R32 Front bumper as well
9. Boser extension steel hood ( needs more work )
Suspension:
1. Mason Tech air ride up front, and firestone air ride in the rear.
2. Bilstein shock also in the rear.
3. Frame notched up front, to allow the subframe to lay on the ground.
4. 5 gallon Air Tank
5. 8 1/2in SMC valve set up.
6. 2 Viair 480cc air compressors.
7. Easy Street digital management with auto ride height
Engine:
1. Stage 3 turbo kit.
2. Gt28rs 60 trim turbo.
3. Bosch 650 cc injectors.
4. 255 walbro fuel pump.
5. Scat performance rods.
6. FMIC.
7. Revo stage 3 tune.
8. 3 inch custom v band turbo back exhaust.
9. New South interior matching boost guage in column pod.
10. Tial 38mm external wastegate.
11. 4 bar fuel pressure regulator.
12. tt225 manifold swap.
13. custom short air intake
14. Southbend Stg 3 VR6 6 speed clutch and lw f/w.
15. 02M 6 speed Swap
16. Deleted SAI and other useless vacuum sources for a cleaner bay
17. Rear mounted battery, with 1/0 ga wire power and grounds
18. VF Engineering Motor Mounts ( All Three )
19. WOT box and 2 step launch control
Extras: Will come with another subframe and steering rack, and I have a ton of misc VW stuff that will come with as well.
Interior:
GTI bolstered sport black leather interior in great shape... all stock except for boost gauge and air ride management
All the install was done at 50k with a rebuilt head, timing belt, water pump etc...
Bad:
Will Start after a charge but I have a drain due to constant running fan. Need to chase the electrical demon down. Its either the fan, a connection that is drawing constant and draining the battery, or the rad temp sensor not turning off the fan. (Have sensor NIB)
Rear Hatch lock needs to be replaced. Hatch will not open. (Have new latch)
Needs a paint job/touch up for the new hood and front bumper. Has surface rust where the winters rubbed the rear quarters.
Rebuilt title from maryland caused a salvage here... Airbag deployment due to riding low from previous owner caused curtain airbag deployment. Has light on because of it
CEL for SAI delete.
I am parting it on Sunday. Car will be available till then...
WILL TAKE 9,000 Bottom dollar (EW price) for the car as a whole as is right now...
612-770-3040
Aaron
Im just sayin.......
