My axle rubs every once in a while with the stock sway bar- looking for something aftermarket that has bigger space between the axle and the bar- let me know what you have, Thanks.
Delete and enjoy less understeer.
What is your intention for the car? Very low static, bags, or sporty?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
I would suggest looking into an under axle sway.
(•_•)
( •_•)>⌐■-■
(⌐■_■)
lift car to a reasonable height. Enjoy nicer ride![]()
Malone Tuning Dealer
VW/Audi/CRD Gas and TDI tuning including DSG tuning.
Longer sway bar end links?
Then remove the sway bar. Problem solved.
Seriously, remove the sway bar. You'll find that your stiffer lower suspension will ride even better, plus you will get less wheel spin in corners.
If you are in doubt, unhook the end links and tie it up and drive around for a few days.
Do not do that.
Proper removal and replacement of the sway bar will require dropping the subframe. Hotchkis used to sell an under axle sway. I believe Die Frau also has one on his MK4, but not sure of the brand.
(•_•)
( •_•)>⌐■-■
(⌐■_■)
do not try no front sway bar?
Easiest way to remove it is chop it in the center and pull it out both sides. No dropping the subframe.
