SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD- 1990 Jetta GL 8v Manual. 199XXX miles. Solid car. Dent in front fender as you can see from the pictures. Yes, there's some rust here and there but nothing major. Under body and floorboards are actually VERY clean. Newer exhaust, clutch, throttle cable. Tires are pretty decent. Headliner doesn't sag, and no water leaks inside. A/C does not work. Heat works great though. Fairly clean inside (but not going to lie, kinda smells like old man).
Found this out after listing it, but There is water in the oil. It looks to me like the head gasket popped, or there's a crack in the head.
- So Price is now SOLD. Or will trade for known working Longitude K04 or k03 turbo.
Recently done =
Water pump
Drivers window regulator
Speedo cable
Replaced Power steering pump
Both Parking brake cables
Both rear wheel cylinders
LED instrument cluster bulbs
Battery
Battery cable
Cap
Rotor
Plugs
Brand new radiator
Needs:
Front Crank seal. (yes it leaks oil)
Rear Drivers side door doesn't open.
Bumper?
Turn signal.
Head gasket or head.
Fix the head gasket or head now - turn it into a project later. Asking $500.
