Page 1 of 4
1 2 3 4 LastLast
Results 1 to 15 of 47
Thread: 2006 gti mkv
    Far away
    VW
    Default 2006 gti mkv
    sold
    It is not that you CAN'T, it is that you don't know how..... YET
    VIPness
    This is my old GTI. If I didn't just pick up a GTO, I would consider buying it back. Good luck, Jon.
    The car has APR Stage 2. Needs HPFP for 2+. Package 2 is highest option package for the 06 GTI.
    You may want to stop into an APR dealer to make sure you don't need a re-flash of the ECU.
    (•_•)
    ( •_•)>⌐■-■
    (⌐■_■)
    Far away
    VW
    Quote Originally Posted by Casper View Post
    This is my old GTI.
    Before the turbo gave out, it didn't feel stock. But, I didn't drive a bone stock one side-by-side either.
    Oct 2010
    Duluth, MN
    Diesel Westy & 2 B5 A4's
    If I didn't just buy my Audi, I'd be considering this. Glws.
    You buy weird cars.
    VIPness
    The driver's door can be repaired under recall.
    (•_•)
    ( •_•)>⌐■-■
    (⌐■_■)
    Far away
    VW
    Oh? I went in to check all recalls, and the only thing showing as remaining was an airbag sensor, which did fix the airbag light finally.
    VIPness
    The door was more of a manufacturing defect. Stop in to any vw dealer and they should warranty the repair.
    (•_•)
    ( •_•)>⌐■-■
    (⌐■_■)
    Far away
    VW
    Very interesting, I will check that out. Thanks.
    SSP
    '91 Audi 200 20v Avant
    what's the door thing you're referring to?
    Oct 2008
    Plymouth
    MKV GTI
    It's not actually a recall, but it is a TSB and it might actually be a warranty extension. Regardless, stop by a dealer and I'm sure they can get you sorted.
    -Ryan
    SSP
    i'm wondering if it's the same problem my rabbit has. the key fob doesn't unlock the hatch 80% of the time, and the drivers door lock will go crazy sometimes, locking/unlocking itself.. no more door chime either or honk when it's locked
    Far away
    VW
    There is a small fold on the bottom on the driver side where the hinges are. It has made a crease in the metal. Electrically, it works just fine.
    so this needs a turbo ($800) and 4 tires ($600) to be able to be driven to see if it needs anything else?
    How many miles?
    Hows the suspension?
    Hows the brakes?
    did you put a tbelt in it with the newer engine?
    Far away
    VW
    Quote Originally Posted by veedubmechanic View Post
    How many miles?
    Hows the brakes?
    It needs a turbo ($x,00, depends on what you want). It you want it for $8500, it needs new tires. If you want it for $10.500, it doesn't, and you get a set or rims for snow tires
    62,xxx miles
    Suspension is coil-overs in the front (recent), other in the rear. Comes with matching coil overs to put in the rear.
    Brakes are fine.
    newer engine was said to have around 27k on it. No belts have been done. Oil change is within 100 miles of current ODO.
    Aug 2008
    Mason City, IA
    1989 BMW 325I
    So it for sure just needs a turbo to run? I might be interested actually as long as we know whats keeping it from running.
    Edit: never mind I just noticed that it does run and drive. So does the turbo just not build boost or possibly have bad seals?
    Flickr @michael_colby on instagram
  1. 2006 lr3 se v8
    By JTapper in forum Cars Classifieds
    Last Post: 08-04-2012, 08:26 PM
  2. FS: 2006 BMW M5 CPO'd
    By ktan in forum VW-Audi Car Classifieds
    Last Post: 07-23-2010, 08:57 PM
  3. FS: 2006.5 vw gti mkv
    By ShanoGTIMKV in forum VW-Audi Car Classifieds
    Last Post: 05-13-2010, 10:28 PM
  4. FS: 2006 Evo IX
    By 20thAE_GTI in forum VW-Audi Car Classifieds
    Last Post: 07-22-2009, 11:09 PM
  5. Fs: 2006 Gti 2.0t
    By MacDalund in forum VW-Audi Car Classifieds
    Last Post: 04-11-2008, 09:29 PM
