Results 1 to 13 of 13
    New Richmond WI
    GLI, Caddy, VRT
    Default Brakes, who knows about em? huge headache here
    MK1 braking system
    when i purchased the car, i had SOME braking power, it sat for 10 years but i did actually have some.
    fast forward to now
    i removed the master cylinder and purchased a new unit
    i removed the brake booster and painted it
    I bench bled the master and reinstalled both units to the firewall
    When the car is OFF, i can build pressure in the pedal to where it feels somewhat firm, but as soon as i turn the car on, the pedal goes all the way to the floor very loose right away, no pressure at all. while running, if i pump the brakes as fast as i can i get a hint of pressure built up, but as soon as i stop pumping for a second it will go back to the floor with zero effort.
    I went and replaced both rear wheel cylinders and made sure everything was nice and tight.
    Bled the entire system from right rear- left rear- right front - left front.
    this has been a constant headache because ive been fighting to get on the road for weeks and this is whats holding me up. does anybody have an idea on where to look?
    Quote Originally Posted by 16vguy View Post
    Body guys are not race car builders, for the most part. They make shit shiny. Which is awesome..
    Jun 2009
    Hwhite Bear Lake
    1992 Audi 100CSq
    Invest in a good parachute.
    Como.
    911, JKU, 330i.
    Are the bleed valves on the calipers facing upwards?
    Quote Originally Posted by The_Stig View Post
    My man a bum he say he aint the daddy n e ways.
    New Richmond WI
    GLI, Caddy, VRT
    Yes they are
    did you put a new gasket between the master and the brake booster?
    New Richmond WI
    GLI, Caddy, VRT
    Yes, one was supplied with the new master
    You must have air in the hyd system then or the master is leaking internally
    Jun 2010
    Hudson, WI
    04 A4 USP
    I had a problem like this on an old grand cherokee and it ended up one of my rear drums was siezed up.
    Quote Originally Posted by bowls
    Who has/can refer me to someone with a lift that is bored and wants to get smoked up?
    New Richmond WI
    GLI, Caddy, VRT
    i just replaced both wheel cylinders
    2011 Golf Variant SE 2.5
    I had a similiar situation once and it turned out to be a faulty check valve for the vacuum on the booster.
    Have you adjusted the rear shoes? If they are way way out of adjustment it will have a air in the system like feeling.
    New Richmond WI
    GLI, Caddy, VRT
    Ill try to source another check valve. I have both vaccuum openings plugged up on it. A friend had suggested I adjust the brake shoes. I noticed the shoes themselves were just about done for anyway. Maybe time for new ones
    Quote Originally Posted by veedubmechanic View Post
    This
  1. A HUGE HUGE thanks to Chad and SCI
    By superhero in forum Euro Automotive Discussion
    Last Post: 05-30-2011, 08:08 PM
  2. Replies: 3
    Last Post: 02-20-2010, 09:22 PM
