Results 1 to 10 of 10
    Jun 2009
    Buffalo, MN
    2012 Beetle Turbo
    Default Absolutely stumped....
    I have no idea what is wrong with my car. I will be driving along happily, car running great, good power, I might be singing, possibly some Journey, and then BAM, the battery light comes on in my cluster, and I lose all power. It doesn't die, and it idles fine, it just loses its balls completely (0-60= 10+ seconds).
    Then the light will go away, and power returns to normal. So I write it off as a weird fluke, then maybe I downshift and increase throttle pressure to change lanes, or to turn around a corner, and BAM, light comes back on, and power goes away.
    I can hear my turbo spooling away as normal, and the DV still makes a pleasant chirp when I let off of the throttle, but it feels as though the wastegate is wide open.
    What the hell is wrong with my car? It only happens when the battery light is on. I'm baffled. Go!
    GS430
    check your grounds and replace your battery
    (•_•)
    ( •_•)>⌐■-■
    (⌐■_■)
    337, '98 Jetta GLX
    Bad ground?
    Quote Originally Posted by 9jetta6 View Post
    Oh dang it does look like its chopped in the back there. Clicked on the link, if its actually legit and can run good, looks fun.
    Jun 2009
    Buffalo, MN
    2012 Beetle Turbo
    Battery is less than a year old with about 10,000 miles on it. I'll check the grounds though.
    Minneapolsota
    Mk2/B3
    Check the ground under the battery tray, and all the grounds, actually.
    New Richmond WI
    GLI, Caddy, VRT
    had something similar happen in my rabbit. one of the wires for the alternator plug came loose. but it would intermittently work/not work. so the light would come on and i would be on battery power, and then it would regain connection and id be back on alt power
    Quote Originally Posted by 16vguy View Post
    Body guys are not race car builders, for the most part. They make shit shiny. Which is awesome..
    only time the batt light comes on when running is when the alternator is not outputting proper voltage.
    check battery voltage when running or have the alternator checked.
    And check the blue exciter wire going to the alternator.
    duluth
    old passat wagon.
    make sure the big power wires on the fuse block above the battery aren't burning up, and make sure none of the fuses have gotten melty.
    Quote Originally Posted by Driv3r View Post
    Look man don't start talking shit!
    Cakeville, MN
    GTI3RS v4.0Cali.Ltd Turbo
    If the women don't find you handsome, they should at least find you handy.
    ~Red Green
  1. Absolutely nuts Z4 drift car.
    By mattdesmond in forum Euro Automotive Discussion
    Last Post: 03-27-2011, 10:51 AM
  2. I'm stumped. 92 GTI clutch job
    By SlimMJS in forum Technical
    Last Post: 05-04-2010, 11:55 PM
  3. im stumped...
    By sgt snuffles in forum Technical
    Last Post: 05-21-2008, 10:56 PM
