Page 1 of 3
1 2 3 LastLast
Results 1 to 15 of 32
    Warren, MI
    50mpg double wishbone
    Default Headlight conversion questions
    Hi guys. I have been planning on doing a fixed headlight conversion on the '92 Anal Probe for awhile now and couldn't figure out how to do it cheaply enough. Then I had an idea today and would like to ask you guys a few questions.
    The car has two regular sized halogen pop up headlights which are hard wired in. Old picture
    I was originally planning on building a bracket to keep them in the "up" position, but lowered down with a bumper cutout like so.
    But the core support is in the way, meaning the lights will still stick up a bit.
    I was wondering if I could use small headlights and buckets from an early 80's car.
    This would allow me to mount two in the original locations with lexan lenses, and two elsewhere on the front end, likely in the grille area.
    Questions:
    -Do the smaller lights use the same kind of wire, ie will I be able to simply cut and extend the stock wires?
    -How do the high and low beams work? Is each pair either high or low? Will I need to wire this differently?
    -Will there be a compatibility problem switching from halogens to regular?
    Thanks!
    PS- The reason for this is aerodynamics. Pop up headlights in the "on" position create a lot of drag.
    and mesmerizing. Ive never considered how much those balls move about until now.
    337, '98 Jetta GLX
    What about adapting a kit from an NA miata?
    http://mazdaroadster.net/showthread....l-Light-Thread
    Quote Originally Posted by 9jetta6 View Post
    Oh dang it does look like its chopped in the back there. Clicked on the link, if its actually legit and can run good, looks fun.
    Warren, MI
    Thought about adapting from an S13 or FC RX7 but ultimately it comes down to money. As in I need to spend as close to zero as possible.
    Also. The headlight motors and/or linkages are FUBAR. To raise or lower the lights I have to physically pry off/shove on the linkages.
    Volt. XC70.
    don't drive at night
    Jun 2009
    Apple Valley
    B1 / E24 / P38 / VZ
    sounds perfectly logical. a lot less work too
    VZ Monaro CV8 | E24 633CSi | L322 Range Rover SC | MK1 Scirocco S | Projekt German AG
    Warren, MI
    Thanks for all the help guys.
    Not.
    Collegeville, MN
    Merkur Scorpio
    Those GM "mini quad" sealed beam headlights contain one filament per housing, so you'd need two per side if you desire high- and low-beams.
    "I don't entirely know what OCD is, but I know it's very fashionable to accuse people of having it if they try and do something properly." -James May
    Warren, MI
    Awesome. Thanks Colin.
    So I would have to find the high beam switch and take off a separate wire to the high beams bulbs? If it's as simple as adding a wire to it I think I could handle that.
    855 Turbo x2
    Maybe use a projector headlight fro ma junkyard car?
    Nobody sits like this rock sits. You rock, rock. The rock just sits and is. You show us how to just sit here and that's what we need.
    Warren, MI
    are those more involved to hook up?
    855 Turbo x2
    you might have to wire in a relay or two, but it's all pretty straight forward. Not to be confused with HID, projector lights just place a glass orb in front of the bulb to redirect light.
    The hardest part would be fabricating a housing that would keep moisture out.
    Warren, MI
    I'll look into it. Thanks Glen.
    Sep 2009
    Burnsville?
    325ix 325ix 325ix 325ic
    Check out 1994 olds cutless headlights. They might just be what your looking for.
    Warren, MI
    Unless I cut that front bracket away it's not going to fit there. But I like where this is going! Keep the ideas flowing!
    If the bracket is not necessary I may just hack it off. Will check it out after the paint job is done. The Olds unit would be slick if it would fit there.
    Hopkins
    Audi B2, B3, 944, e30's
    Cut some holes and fab up your own buckets. As far as wire gauge goes, just use the same size or smaller (gauge).
    So is your mother, but we have restrictions on size around here.
  1. Replies: 0
    Last Post: 07-29-2012, 09:26 PM
  2. Conversion Advice
    By Cspence024 in forum Technical
    Last Post: 04-24-2010, 05:05 PM
  3. E30 5-lug conversion?
    By JTapper in forum Technical
    Last Post: 11-17-2009, 07:52 PM
  4. HID conversion ?'s
    By Fearnside in forum Euro Automotive Discussion
    Last Post: 11-16-2009, 04:06 PM
  5. 16v conversion kits???
    By Eyedeas in forum Euro Automotive Discussion
    Last Post: 10-28-2008, 06:02 PM
