Many parts added, thread cleaned up, prices dropped on 3/24
all prices are picked-up in Minneapolis
E30 full headgasket-waterpump job kit, NIB - $120
- Reinz HG set (manifold gaskets, head gasket, WP gasket, etc etc etc)
- Graf water pump (for 325i, up to 1987 M.Y.)
- head bolts set, thermostat, radiator hoses, radiator mounts, reservoir cap, timing tensioner spring, etc etc etc
- anybody planning an M20 rebuilt/refresh should buy this... it's about $250 worth of parts, just needs fresh belts
E30 4dr window weather strips, NIB - $50
- at one point yours were made of pliable rubber, and kept water out, like these
- cost new is $110 + shipping (they are a special order part)
E30 trunk gasket seal, NIB - SOLD
- at one point yours was made of pliable rubber, and kept water out, like this one
E30 325i Front brake pads, NIB -- $20
- PBR brand, still in box, new
E30 325i brake rotors, four new -- $50
- never used, new
E30 325i pressure plate, and clutch disc -- $60
- clutch plate is 3/8" wide; about 8k miles on this; still lots of life left
84-87 euro bumpers -- SOLD
- chrome, includes all hardware that held them onto the car they came from
- grey market (european) style bumpers, front and rear
- no shipping on these
E30 325i ECU / motronic DME -- $50
E30 325e ECU / motronic DME -- $20
E30 325i alternator -- $20
E30 M20b25 cap/rotor/wires -- $40
- very little use, about 8k miles
E30 set of 4 brake calipers, including all brake pads (1000 miles on those) -- $100
- I bought them from a guy who did a 5-lug swap to his track car. He said he rebuilt them.
- Includes a new set of pads all around with 5k miles DD use
E30 325ix steering rack -- $120
- came from 1989 automatic w/130k
- no leaks! includes reservoir and plumbing
E30 325ix passenger-side control arm -- $100
- (price new is $240)
- used; PN 31121701060
- boots are intact, bushing is good
E30 325ix driver-side control arm -- $60
- used; PN 31121701059
- bad ball joint. ball joint is serviceable
E30 325ix driver-side tie rod-- $100
- brand new, PN 32211701039
E30 325ix engine harness -- $60
- it is from an automatic transmission AWD car
E30 325ix washer fluid tank -- $30
- with NIB washer pump
- you'll need/want one for engine swaps, whether M30, M50, M52, S50, S52, et cetera
e23 / e28 Large trunk toolkit -- $40
- includes all you see in pic
E28 Kick panel, tan -- $30
E28 M30 valve cover -- $40
- powdercoated grit black
E28 Getrag 265 transmission mount -- $20
