Results 1 to 4 of 4
    Buffalo
    VW Golf vr6
    Default Chains, Guides, Clutch and some seals MK3 VR6
    It is time to do some maintenance on the VR6. what would be easiest way of doing this? removing the front of the car, pulling the engine out etc. After I do this maintenance I may put the turbo setup in the golf for a little while. suggestions are appreciated.
    Oakdale/Maplewood
    GLI gas guzzler
    I've only done this with the motor out so I can't really compare. But with it out it was cake if you have an engine stand.
    I might suggest getting a 42dd crack pipe, too.
    minneapolis
    95 VW GTI VR6
    it isn't hard w/ the motor in car, that way A/C, coolant, and steering can all stay attached....it is just sucks dealing w/ the trans.
    Buffalo
    VW Golf vr6
    Thanks for the input guys. Either way has its good and bad.
  1. Replies: 9
    Last Post: 12-10-2011, 02:02 PM
  2. Handy Tire Guides - Estimate Your Stretch!
    By The_Stig in forum Wheels and Tires
    Last Post: 04-05-2011, 10:52 AM
  3. Clutch and timing chains-need installed
    By jonnyblayz in forum Technical
    Last Post: 01-21-2010, 01:58 PM
  4. chains :(
    By poorscheg60 in forum Technical
    Last Post: 11-13-2009, 10:51 AM
  5. WTB Rabbit Door Seals and some window seals
    By vweezly in forum VW-Audi Car Classifieds
    Last Post: 03-15-2008, 01:19 AM
