going with a different set up, looking to see what i could get for my motor and tranny its a 1991 m42 with a eaton m62 supercharger im almost to 150k and still running strong, the blower was put on around 90k running 7-10 psi depending on belt tension and other factors. the blower was used when installed, it came off of a nissan xterra i replaced all the front end snout bearings, however the rear rotor bearings are getting pretty loud and will need to be replaced soon. still runs excellent i daily the car. the PO who made and installed the SC kit also installed a knock alert sensor and i havent seen or heard a peep out of it since ive owned the car. the tranny and clutch are strong no slippage or grinding. ECU and engine harness are included too im running a narrow band o2 guage and FMU for fuel under boost. so 02 and boost guages will be included too. seriously considering getting the car dyno'd and running it at the drag strip within the next couple weeks. my GUESS for power is maybe 180-190 at the wheels, PO said it ran a 13.4 in the 1/4 which is probably.
anyways this would be a gnarly swap for a someone with a 2002 or another E30, pm me for any questions and let me know what ya think its worth.
filmed in canada on private property.
BRASS KNUCKLE SHIFTING
