Thanks! The costs aren't bad at all. Same as any other european car pretty much. If you are used to the older audi's than these are probably a breeze.
Most of the OEM parts are good quality, so when something does break or wear out, usually I replace it with a better condition factory used part, which usually holds up fine and also saves me a ton of money. Its good to have a parts car around!
- Elliott
86 944 Turbo (x4)
86 944 Supercharged
