Results 1 to 15 of 15
    Feb 2010
    Saint Cloud
    08/91 325i, 05 4Runner
    Default Anyone have special VW tool 3366? Have a P0171 code...
    Need to do the cam tensioner gasket and half moon on my 2004 AWM 1.8t.
    Seems to be leaking from that area, but I was told it would only be oil and not air coming from that area... Which makes sense since it is an oil seal.
    Maybe I just need some help with that code itself.
    With the cel on: the SAIP does not turn on and the engine does not start at a higher rpm like usual upon cold start up, mileage seems to be the same as before the code kicked in, I made this http://www.a4mods.com/index.php?page...boostleak.html and did the deed and the air is leaking from the cam tensioner area.
    I suck at electronics and vacuum shit. Please help it you can! I believe the leak to be coming from this area as the vacuum hoses seem fine and the pcv system seems fine too. I just want to fix what is wrong and not dump money into things that I can do later.
    Thanks in advance for your help to this nOOb.
    08/91 BMW 325i Sedan
    2005 Toyota 4Runner SR5 4WD 7pass
    Get your classic car restored here: swedalclassics.com
    Location?
    Wait...
    You pressurize your intake to check for boost leaks and your tensioner gasket passes air?
    Dec 2007
    Overland Park, KS
    B5 A4
    Wait...
    Yeah... That shouldn't happen.
    edit: Hold on, if OP is pressure testing from the TIP and didn't disconnect the PCV system that would be possible, correct?
    No. I'm pretty sure his PCV valve should hold the pressure.
    Dec 2007
    Overland Park, KS
    B5 A4
    I've always been unsure of that. The TIP is under vacuum during normal operation, being that it's before the compressor.
    I wish I knew more about how the PCV valve/system worked. Some people say you should disconnect it when pressure testing and some people say you don't.
    337, '98 Jetta GLX
    I sent you a PM. I'm local and can give you a hand troubleshooting.
    Quote Originally Posted by 9jetta6 View Post
    Oh dang it does look like its chopped in the back there. Clicked on the link, if its actually legit and can run good, looks fun.
    Feb 2010
    Saint Cloud
    Did not disconnect the PCV system. Car seems to run well when not under boost. When you give it some beans (merging, accelerating out of corners) seems to be doggy. Mileage is still good though returning 33.3mpg's via the OBC on last nights trip.
    Air is leaking from the cam tensioner area fo sho. Should be or shouldn't be, but it is for a still undetermined reason.
    Thanks for the inputs. I hope to meet with Justin as he says he is an expert in all things 1.8t
    Dec 2007
    Overland Park, KS
    B5 A4
    Be sure to report back here with your findings. I'm interested to see what you come up with.
    337, '98 Jetta GLX
    I didn't use the word expert, but I know enough.
    air will leak past that seal if its worn out and leaking and there isnt silicone there. When a new cct gasket and half moon are installed, silicone is to be used in the correct spots, including the rubber seal .
    Feb 2010
    Saint Cloud
    ^^I have read that too and in my case it takes a decent amount of PSI to get the leak to show; must be a tiny leak.
    Justin stopped over yesterday after his 10 hr day of work (thanks again, you are the man, chocolate chip cookies are going to happen this weekend) and we poked around the bay for awhile. Cleaned the MAF, he confirmed my suspicion of the leak area and what to do, and he Vagcom-ed the shizz out of the Passat.
    I'll see how it does the next couple of days since I did not get a chance to drive around last night since I am old and need my pillow early these days. Thanks for the thoughts and I will update this as I notice new things or discover new leaks
    337, '98 Jetta GLX
    There were codes for system too lean (bank 1) and for MAF value too high. I have the log on my laptop and I'll post it after work today.
    Feb 2010
    Saint Cloud
    Popped back on right away after cold start up today. SAI does not seem to be activating at any time, do not know if CEL and SAI are in cahoots.
    337, '98 Jetta GLX
    Here's the scan log:
    Wednesday,06,June,2012,17:56:29:08507
    VCDS Version: Release 11.11.1
    Data version: 20111209
    Chassis Type: 3B - VW Passat B5
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    VIN: WVWVD63B14E019532 Mileage: 158500km/98487miles
    Address 01: Engine Labels: 06B-906-018-AWM.lbl
    Part No SW: 4B0 906 018 DP HW: 8E0 909 018 A
    Component: 1.8L R4/5VT G 0003
    Coding: 0016501
    Shop #: WSC 02408 444 58702
    VCID: 72F6D18E6EB4019
    2 Faults Found:
    16487 - Mass Air Flow Sensor (G70)
    P0103 - 001 - Signal too High - MIL ON
    17544 - Fuel Trim: Bank 1 (Add)
    P1136 - 001 - System too Lean - MIL ON
    Readiness: 0000 1101
    Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
    Part No: 3B0 614 111
    Component: ABS/ASR 5.3 FRONT D00
    Coding: 00022
    Shop #: WSC 05314
    VCID: D3B8F40A21EEE81
    No fault code found.
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 C
    Component: 09 AIRBAG VW61 04 0003
    Coding: 12345
    Shop #: WSC 05311
    VCID: 245AE7D6B4C0DF9
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
    Part No: 3B0 920 929 BX
    Component: KOMBI+WEGFAHRSP VDO V04
    Coding: 15235
    Shop #: WSC 02408
    VCID: 7EEEF5BE7AEC559
    WVWVD63B14E019532 VWZ7Z0C7586924
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 03751
    VCID: F0F25B86B0B8B39
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 C
    Component: 80 Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 05311
    VCID: 3760209A1556A41
    Subsystem 1 - Part No: 1C1959801
    Component: 80 Tőrsteuer.FS KLO 0202
    Subsystem 2 - Part No: 1C1959802
    Component: 80 Tőrsteuer.BF KLO 0202
    Subsystem 3 - Part No: 1C0959811
    Component: 80 Tőrsteuer.HL KLO 0202
    Subsystem 4 - Part No: 1C0959812
    Component: 80 Tőrsteuer.HR KLO 0202
    2 Faults Found:
    01389 - Tailgate Open Switch (F124)
    27-10 - Implausible Signal - Intermittent
    01141 - Luggage Compartment Unlocking Switch (E165)
    27-00 - Implausible Signal
    Address 56: Radio Labels: 3B7-035-1xx-56.lbl
    Part No: 3B7 035 180 G
    Component: Radio NP2 0016
    Coding: 00031
    Shop #: WSC 05311
    End ---------------------------------------------------------------------
  1. 12v VR6 code
    By jonnyblayz in forum Technical
    Last Post: 06-06-2012, 11:29 AM
  2. Replies: 3
    Last Post: 11-30-2011, 01:53 PM
  3. Buy/Borrow VAG tool 3366 (Cam tensioner tool)
    By JTapper in forum VW-Audi Parts Classifieds
    Last Post: 10-12-2010, 09:11 PM
  4. code help
    By terrance roush in forum Technical
    Last Post: 09-26-2010, 02:03 PM
