Results 1 to 12 of 12
    May 2008
    Syracuse, NY
    '98 Passat Variant 2.0T M
    Default Mk4 A-chassis Front Suspension/Control Arms/Bushings
    Recently purchased an '01 TDI for my GF. At 160k miles the suspension is just plain tried. For the most part the car has been maintained very well. So far I've acquired Bilstein shock/struts all around, H&R Race springs, Hotchkis 27mm front sway bar, H&R 28mm rear sway bar.
    What else should I be replacing? I've heard strut bearings/mounts, ball joints, tie rod ends. School me on Mk4 weak points.
    Currently I'm looking at this Stg 2 refresh kit from ECS for $180. Looks like it covers everything including the upgraded TT control arm bushings. I've heard these can fail. I have access to a good press, so replacing these wouldn't be an issue.
    http://www.ecstuning.com/Volkswagen-...Kits/ES248440/
    LINKS: B5 Passat Variant,2L Build,Further Performance
    First to post, last one to get laid.
    May 2011
    St. Cloud, MN
    337, '98 Jetta GLX
    The LCA rear bushings tend to tear. Don't bother replacing them with stock, go with solid R32/TT bushings.
    Quote Originally Posted by 9jetta6 View Post
    Oh dang it does look like its chopped in the back there. Clicked on the link, if its actually legit and can run good, looks fun.
    May 2008
    Syracuse, NY
    The ones included in the fore mentioned kit?
    Oct 2008
    St Paul, MN
    02 Jetta 24VT and 04 R32
    I would go through blunttech and they can ship them directly to you. I have had far too many issues with ecs to ever order from them again. Just give him the link to those parts and they can put the kit together for you.
    Aug 2011
    85 535i,71 Touring,97 M3
    I'd love to help just shoot me an email . we can build you a custom kit if youd like. Sales@blunttech.com
    Jul 2006
    Minneapolis
    VRIANT | MB W204
    The items shown in that kit should pretty much cover it all.
    May 2008
    Syracuse, NY
    A little over the top for the TDI, but anyone ever run the tubular control arms with heim joints?
    http://innfab.com/products/
    Aug 2009
    Wayzata, MN
    GTI 1.8t
    Those are really new, lot's of travel for going low, probably a bit overkill unless you want her car to lay frame.
    Also, take a look at the rear beam bushings, they start to go around that age.
    Jul 2008
    02 GTI 1.8t, 12 Golf Tdi
    FYI, way better kit then the ecs one. I have bought a few =)
    http://www.ebay.com/itm/VW-Golf-Jett...ht_5230wt_1031
    just needs upper mount bushings/bearings for another 28.00
    you're looking up used handguns at school? welcomed to the flagged student list
    Your cock blocking like half the people on eurowerks with that statement.
    Sep 2007
    duluth
    old passat wagon.
    looks like those control arms have the crappy standard control arm bushings.
    I have tt/r32 bushings in two of my cars and love them. my dad loves them in his mk4 2.0, as well.
    Quote Originally Posted by Driv3r View Post
    Look man don't start talking shit!
    Quote Originally Posted by Crispy222 View Post
    Unless your inner tierods are bad go with their Stage 1 kit. IMHO the balljoints, inner tie rods and outer tie rod ends are NOT the weak points on the mk4 suspension.
    As suggested take a close look at the rear swingarm bushings. If you're getting that far into the suspension it would be a good idea to just replace them. Maybe go with the Cupra R set from boraparts?
    May 2008
    Syracuse, NY
    At a 160k miles and no record of them being replaced, I think I'll replace them and just get one alignment instead of one alignment once a year as parts wear out. It will be quite the change going from stock worn down parts to aftermarket spring, shocks/struts, sway bars, with new bushings, bearings, and the like.
  1. mk4 gof control arms $20
    By Tim Chunks in forum VW-Audi Parts Classifieds
    Last Post: 05-10-2012, 12:55 PM
  2. F/S NEW MK4 Control Arms and A arm bushings F/S
    By SurfnWally in forum VW-Audi Parts Classifieds
    Last Post: 03-10-2012, 06:39 AM
  3. Brand new Mk3 Vr6 control arms w/bushings & Mk4 1.8t Axle
    By LB_Erck in forum VW-Audi Parts Classifieds
    Last Post: 02-11-2012, 07:33 PM
  4. Replies: 0
    Last Post: 12-10-2011, 01:42 PM
  5. FS: R32/TT Control Arms with Defcon 1 Bushings and TT Ball Joints
    By briang in forum VW-Audi Car Classifieds
    Last Post: 11-24-2008, 05:06 PM
