Page 4 of 12
FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Results 46 to 60 of 178
  1. #46
    Apr 2012
    2003 Imola Yellow GTI
    The HVAC box had a heater core in it already. Looked brand new so I used that.
    Waiting on the block to get back from the machine shop. but in the meantime ill be drooling over this.
  2. #47
    Apr 2012
    UPDATES! (finally)
    Got some goodies from 1stpartsvw. New coilpack harness, the old one was starting to crack so why no replace it now? So sick of wiring though...
    New power steering pressure switch
    New slave cylinder
    New seals for the quick release connectors on the radiator
    New hose for the coolant ball
    6 clutch bolts, didn't want to reuse the old ones.
    New fuel filter
    Rubber cup holder inserts because I hate how anything in the cup holder rattles. They are a little too big so they will have to be trimmed down.
    Took the shifter bracket out to clean in up a bit and install new bushings. No more rubber in the shifter at all. Can't wait to see what difference these make.
    Before:
    After:
    Cleaned up and slightly polished the trans.
    My OBD2 port bracket cracked. Anyone know a part number for this? Cannot find one anywhere stamped on it, or online.
  3. #48
    Apr 2012
    Moar updates.
    Finished installing the installing the new coilpack harness(never again, this sucked to do )
    Steering wheel and center console are back together
    Installed my early Passat mirror switch from Europe
    Painted the sub frame because there was visible rust.
    Coilpack harness ECU side, suck to work with as there are 3 safety keepers to keep the wires from moving(Purple things on the left)
    Just add this into the correct pins. Wires are labeled for the correct pins from the factory.
    Sub frame before(MN winters....)
    After.
    Moved the brushed handle over to the new bezel.
    Wiring it up and getting ready for solder.
    Pin 2 on the passat switch to Pin 5 on the Mk4 harness(Gray/Blue wire)
    Pin4 on the passat switch to Pin 10 on the Mk4 harness(Gray/Yellow wire)
    Pin 6 on the passat switch to Pin 6 on the Mk4 harness(Gray/White wire)
    Pin 8 on the passat switch to Pin 8 on the Mk4 harness(Brown/Blue wire)
    The remaining 2 wires are for defrost. That will be wired up the CCM later and controlled by the rear window defrost switch. This is how it was across the pond, and how it should have been here.
    Radio area fully assembled
  4. #49
    Mound
    72 911T, 1980 Golf, 300D
    all the wiring makes my head twitch. mirror switch is a nice touch!
    "Being powerful is like being a lady. If you have to tell people you are, you aren’t. " - M. Thatcher
  5. #50
    Mar 2008
    St. Paul
    '03 Golf TDI 5M
    Quote Originally Posted by MNShortBus View Post
    Before:
    After:
    do you have part numbers for the cup holder cover and shifter bushings? Also, that is one clean transmission. Looks good.
  6. #51
    Apr 2012
    Its actually a rubber insert, not a cover. I just took that picture for size reference.
    Part number is 1K0 863 301 A
    There is no part number for the shifter bushings, sorry. They were made by a friend and the family business. There may be more but I would have to check.
  7. #52
    May 2011
    St. Cloud, MN
    337, '98 Jetta GLX
    Iirc 42 Draft Designs makes bronze shifter bushings like that.
    Quote Originally Posted by 9jetta6 View Post
    Oh dang it does look like its chopped in the back there. Clicked on the link, if its actually legit and can run good, looks fun.
  8. #53
    Apr 2012
    I believe 42DD makes them for the shifter endlinks only, not the bracket.
    Said bushings:
  9. #54
    May 2007
    95 watermelon
    6n0 972 559
  10. #55
    Apr 2012
    Sweeeet. Thank you!
    Too bad I just put in another order for parts. I'll have to wait until the next one.
  11. #56
    Jan 2011
    Forest Lake
    B5 Passat TDI, 951
    Just hit up Johns Auto and pull the bracket from a vehicle.
    Malone Tuning Dealer
    VW/Audi/CRD Gas and TDI tuning including DSG tuning.
  12. #57
    Apr 2012
    Made a lot of progress this weekend despite having to but everything away for next weekends grad party.
    Girlfriend got some parts powder coated for me for my birthday.
    Polished the valve cover nuts, engine mount bolts, and other random things.
    Installed the new coolant ball and hose.
    Installed the new heater core hose. The old one was rubbing on the brake booster creating a hole, luckily it never burst open.
    Replaced the o-ring seals on the quick connects on the radiator.
    Installed the new cabin filter.
    Replaced the broken supports for the panel under the drivers side dash. It doesn't sag anymore.
    iPod hookup is now back in the car.
    Put the door panel back on after installing the mirror switch and rewiring the defrost operation.
    Interior is now 100% back together.
    Installed the Komfort Blinker retrofit kit (3 blinks with the tap of the turn signal stalk).
    Replaced the fuel filter. The previous one had about 40k on it.
    Battery holder and wires are now back in place.
    Powdercoating!
    These are the nuts for the valve cover. Should look great next to the black.
    Komfort Blinker from VW. Part number: 000 998 229 A
    Installed.
    Time for some Comfort Control Module education...
    I went the extra mile and decided the change the way the mirror defrosters work. Since the new mirror switch doesn't have the defrost function on it I have to change the way they get the signal to turn on. In Europe the rear defrost switch sends a signal to the Comfort Control Module (CCM) and then that device controls the defrost function.
    On the mirror switch Pin 7(voltage supply) and Pin 9(CCM signal) have to be left in the connector, and insulated. Or remove the wires completely.
    From the rear window switch run a wire from T7/3(7 pin connector, pin 3) to T23/16(23 pin connector, pin 16) on the CCM. You will need to remove the wire that is in the there currently and insulate the end.
    This is for CCMs with part number 1C0 XXX XXX. All 20ths should have this part.
    CCMs with part number 1J0 XXX XXX the pin to remove and run a new wire is T23/1.
    Pin 16 removed
    New pin 16 added. I used a section of wire and the connector from my old coilpack harness. Worked perfectly.
    This came out of my fuel filter when I tipped it upside down... ISH.
    Picture of the new trans mount with the polished bolts.
    New coolant bottle. Walbro pump lurking in the back.
    Battery tray back in.
  13. #58
    Apr 2011
    maple grove
    mk3 jetta
    dang dude, keep up the work!
  14. #59
    Jun 2008
    St. Paul, MN
    05 Audi A4 1.8T
    Did you polish the nuts and bolts yourself?
    Official TeamB0N4R Member #512-21B
    "Fuck You, You're Gay"
  15. #60
    Apr 2012
    Yeah, I used a dremel and some different sanding disks.
    These:
    and these:
  1. The Campwerks Picture thread
    By audivwdave in forum The Annual Campwerks Show
    Last Post: 02-06-2012, 12:53 PM
  2. Replies: 41
    Last Post: 05-04-2009, 04:17 PM
