Page 1 of 12
1 2 3 4 5 11 ... LastLast
Results 1 to 15 of 178
    Apr 2012
    2003 Imola Yellow GTI
    Default 20thAE Build/Picture Thread
    PLANS
    IE 2.0 Stroker Kit 9.5CR.
    Calico Main and Rod Bearings
    ARP Crank Bolt
    AEB Head
    IE Street Cams and Spring Kit
    Supertech Intake Vavles
    Supertech Iconel Exhaust Valves
    OEM Lifters
    Possibly Valve Guides(To be determined)
    ARP Cam Gear Bolt
    Pag Parts Kit - PTE 5857
    Still looking at options for software.
    Need to replace the front bumper and grill at some point too.
    Looking at the euro bumper and rub strip.
    Current
    Engine/Trans:
    Revo Stage 2 Software
    Forge Turbo Inlet
    Forge Splitter DV
    Eurosport FMIC
    42DD 3" Exhaust
    Phenolic Intake Spacer
    P-Flo Intake
    42DD Catch Can
    Emissions Deletes
    Dogbone Mount Inserts
    Shifter Bushings
    Interior:
    False floor with sub/amp
    A/F and Boost Gauges
    LED Lighting Kit
    R8 Trunk Light
    R8 Trunk Lights for foot well lighting.
    .:R Floor Mats
    Passport radar detector mount and display
    Funk Button with Insert
    iPod Adapter
    Jetta vents
    Exterior:
    BBS LM Reps (yeah yeah, who cares )
    FK Coilovers
    OEM Porsche License Plate Lights (DIY: http://forums.vwvortex.com/showthrea...ghts-OEM-Style)
    Smoked Bumper and Side Markers
    Fog Lights
    Helix Headlights - OEM Reps
    Stubby Antenna
    Rear Wiper Delete
    Pict-ars.
    Picture of the foot wells.
    Apr 2012
    Recently finished this. Thanks to JettaGetUpandGo for the idea.
    Euro R32 dash panel, switch insert and a wiring kit from Escort.
    New Tuscan Rods. "AWWWW YEAHHHH.JPG"
    Took the head out of the plastic wrapping. Looks brand new.
    I didn't take as many pics as I wanted but here are some from the Bentley key swap. Ill post some steps if people show some interest.
    3 screws are required to get the whole fob apart. 2 of them are small as can be. Penny for size reference.
    The 2 boards next to each other. Stock VW one on the bottom. They are pretty much the same.
    VW board in the Bentley key. It takes a little trimming to fit in there, and is a little loose. But when the top is on it does not move at all. Took the negative battery terminal (C shaped thing) and soldered that to the contact on the board. The battery hole lines up pretty good. Also took the stock immobilizer chip out and put it in this fob. That was by far the most nerve-racking thing ever. It's glass and VERY easy to break and have a $200 mistake. Finished product is fully functional, besides the LED being in the right spot. I may solder one in for the correct location some day, but who pays attention to it anyways?
    Also came across a Climatronic swap from a Jetta with all the parts still in the car. It kind of fell into my lap, so I may be making that purchase real soon.
    Apr 2012
    Clutch was ordered yesterday
    Made a lot of progress last night. Still deciding if I should leave the AC the way it is or drain out the freon to do a climatronic swap...
    MN
    87 BMW 325e, 02 9-5 wagon
    Chick at bar: "Oh wow you drive a Bentley?"
    You: "No, its a 10 year old Volkswagon"
    Chick exits. Alone.
    lol
    But seriously good work on the car. It looks good. What kind of power are you hoping for?
    Need Prayer?
    wow. some serious plans.
    West 7th
    05 USP Avant, 94 Civic
    in.
    Listen twice as much as you talk.
    Jan 2007
    Rosemount, MN
    MKV GTI
    Sub'd
    It's all good as long as the balls don't touch.
    B5 Passat TDI, 951
    Your list needs a turbo
    Malone Tuning Dealer
    VW/Audi/CRD Gas and TDI tuning including DSG tuning.
    Apr 2012
    Quote Originally Posted by JFettig View Post
    Pag Parts PTE 5857
    B5 Passat TDI, 951
    oh that's what that is
    maple grove
    mk3 jetta
    someone used to have one of these in Maple Grove, sick car anyways.
    Jan 2007
    Rosemount, MN
    MKV GTI
    I think that's where he is from...
    Apr 2012
    Quote Originally Posted by 9jetta6 View Post
    I used to always see 2 others driving around but not any more.
    Hey connor!
    maple grove
    mk3 jetta
    Quote Originally Posted by Fearnside View Post
    yeah, then i saw his other post... im dumb
  1. The Campwerks Picture thread
    By audivwdave in forum The Annual Campwerks Show
    Last Post: 02-06-2012, 12:53 PM
  2. Replies: 41
    Last Post: 05-04-2009, 04:17 PM
