Results 1 to 4 of 4
    Jun 2011
    chanhassen/chaska
    mkiv gti 1.8t
    Default 1.8t awp ecu apr tuned
    from a 05 gti stock,91,93,100 tunes downpipe file is on it needs imob defeat to run in your car but otherwise your good to go $300 open to trades
    Princeton
    Corrado 20v turbo
    No need to make two threads basically stating the same thing. Why are you wanting to get rid of this ECU again, and is it APR stage 1/2??
    Corrado, Scirocco, tomayto, tomato....
    Jun 2011
    chanhassen/chaska
    mkiv gti 1.8t
    haha well true i finally picked up a new ecu i bought a frankenturbo and im trying to put together everything i need and wasn't about to flash over a decent chunk of change and software if u consider apr decent just looking for 440 cc injectors,fmic,and the tune at this point but its apr stage 2 i believe i have the down pipe file so i imagine its stage 2
    NW Dubside
    B5wagon Saab 900se
    Yep your correct stage 2 full blown APR flash!........ I miss my stage3 A4 1.8T
    If you ain't RUBBIN you ain't DUBBIN....
