Results 1 to 3 of 3
    Aug 2010
    Princeton
    86' Jettski
    Default Quick antifreeze question
    We just changed a thermostat in a 98 Aba and drained the coolant.... If I thoroughly flush the radiator and coolant system. Would it harm the motor if I switched to conventional green coolant from g12 coolant
    Nov 2011
    Mankato, MN & Bielefeld Germany
    06 Passat 2.0T
    Somewhere I saw a thread where a guy did a test with different coolants and pieces of metal, came out that G12 really has much better corrosion protection than most other stuff you can find.
    I don't really see the benefit of attempting this either, it could cause you a lot of headaches, and g12 is not that expensive for how often you need to flush or refill coolant that it would be wort switching.
    If the G12 is completely gone, sure, but like posted above, it's superior coolant.
    Just don't mix the two. I've seen the result, it was a fucking headache to clean out.
  1. Quick question for the MKIV guys..
    By Dane in forum Technical
    Last Post: 05-16-2010, 12:20 PM
  2. 2007 GTI Quick Question
    By CaRJoE0220 in forum Euro Automotive Discussion
    Last Post: 12-11-2009, 05:08 PM
  3. quick mk1 badge question
    By Sven7 in forum Euro Automotive Discussion
    Last Post: 08-18-2009, 11:06 PM
  4. quick question for the vr guys
    By poorscheg60 in forum Technical
    Last Post: 07-10-2009, 12:39 PM
  5. Quick Coilover question
    By Fearnside in forum Technical
    Last Post: 05-22-2009, 12:38 PM
