Results 1 to 15 of 29
    Eagan
    89 325ix 2dr and 4dr
    Default E30 parts from 88 ix, 90 325i 2dr/4dr, 87 325ic
    3/16/13 EVERYTHING IS NOW SOLD.
    it all went in one big batch, thanks for everyones business!
    2/25/13 - I'm ready to offload a lot of this so as of now most of the little stuff listed around $5 or so is FREE
    interior and engine bay plastic
    wiper arms
    RWD washer fluid bottle
    gas pedal
    lock actuators
    2dr rear stationary windows with seals
    tan front speaker cover panels
    ALL trunk carpet
    door sill and trunk hard plastic trim
    dash electronics brackets
    metal e-brake arm
    e-brake boot
    tool kit trays
    trunk latch
    hood guide plate
    good tie rod boots
    does NOT include chrome trim or door trim
    Most of you have probably seen my craigs ad but heres some pics and new inventory. Most prices are negotiable, the more you want, the cheaper it is too.
    Sorry gang, I'm not able to ship anything at this time.
    I have tons of spare parts from projects over the years. Mainly from the following cars. Anyone is welcome to come over and dig through it. I just need my space back and want this stuff outta here.
    E30 1988 325ix
    E30 1990 325i 2dr
    E30 1987 325ic
    E30 1990 325i 4dr
    Also have nearly full cars worth of parts at another location for these
    E34 1989 535i
    E36 1997 318i black 4dr
    The big items I don't have are: engines, transmissions, 325e or ETA parts, front seats, cylinder heads, fuel pumps, fuel tanks, IX driveshafts or transfer case.
    Eagan
    Here's the parts from a 4 door 90 325i.
    sold firewall cover for HVAC access
    sold wiper motor vent cover, driver side
    sold wiper arms, pair
    SOLD passenger side headlights
    SOLD driver side headlights
    sold each Headlight buckets
    $5 glovebox plastic trim
    $20 headlight grills, pair
    $20 visors, great shape, no cuts
    $5 tool tray, clean, no rust from tools
    $10 each tail light backers with bulbs
    $5 3rd brake light assembly
    $5 tan, front speaker covers
    $5 trunk/fuel filler lock actuators
    $5 rear view mirror
    $10 rear window motor, I think
    $5 back of headlight covers
    $5 gas pedal, clean
    $5 ceiling handles and screws
    $2 plastic ebrake handle
    $5 airbag top kick panel
    $10 check panel
    $15 ignition coil
    $5 each 3 standard speakers
    sold rear standard speaker cover pair
    $45 Tan vinyl rear seat set, no cuts, just needs a cleaning, very nice
    $5 washer fluid bottle, no pump
    $5 B pillar trim, passenger side only
    $5 coolant tank
    $15 front seat belt retractors/belts, pair
    $10 visor panel - manual sunroof, with plastic insert around handle, some typical bubbling in corners, not perfect
    SOLD radiator - 5spd
    $10 Tan rear deck panel
    $10 valve cover
    $10 a/c compressor
    $20 intake manifold
    SOLD block/oilpan complete below the head
    KEPT Cylinder head
    $20 oil pan
    $20 starter
    SOLD front subframe
    Still available are the sway bar and driver side control arm only
    Rear subframe and attached parts, no brake clipers
    $40 rear subframe
    $50 3.73 diff, non-LSD
    $30 trailing arms/hubs, pair, e-brake lines had to be cut
    $40 axles, good boots, pair
    SOLD driver front strut assemblies complete as shown, strut brand unknown
    SOLD passenger front strut assemblies complete as shown, strut brand unknown
    SOLD rear Bilsteins
    $15 brake booster
    $20 abs unit
    $10 brake master cylinder
    $15 thermostat housing
    GONE passenger side front door, no rust but scratched paint. Glass and motor included
    GONE passenger side rear door, no rust but scratched paint. Glass and motor included
    Here's the original stuff that I have left.
    $10 90 325i 2dr driver rear stationary window and gasket
    $10 88 325i 2dr passenger rear stationary window and gasket
    $65 87 325ic 87 convertible passenger rear window assembly with working motor
    SOLD 87 325ic 87 convertible driver rear window assembly with working motor
    $20 90 325i 2dr center console
    SOLD 88 325ix heated seat button cut out ebrake console
    $20 4 hole center console 2dr I believe
    $5 87 325ic convertible trunk bottom pad
    $5 88 325ix 2dr/4dr trunk bottom pad
    $5 90 325i 2dr/4dr trunk bottom pad
    $10 87 325ic convertible door floor rail pair
    SOLD trunk latch trim
    SOLD flat floor trim, 2dr?
    $5 ? door trim 4dr front?
    SOLD door trim 2dr?
    $5 90 325i 2 dr door trim with chrome stripe
    $5 87 325ic convertible exterior trim pair
    $5 ? chrome trim, unknown
    $10 87 325ic Delphin rear bumper top trim for aluminum bumper
    $5 88 325ix 2dr/4dr front wheel well trim passenger side
    SOLD 87 325ic convertible front wheel well trim passenger side
    SOLD 87 325ic 87 convertible steering rack, unknown condition
    $5 transmission support 90 5spd?
    $10 87 325ic Delphin passenger side rear bumper trim
    $5 87 325ic convertible trunk trim top piece
    $5 ? trunk trim, unknown
    SOLD 90 325i blower resistor
    SOLD 88 325ix IS Sport lip spoiler. Very good condition
    $5 ? glovebox top trim
    $5 ? glovebox left trim
    $5 ? steering wheel trim
    $5 ? driver side headlight backer trim
    free ? blower motor cover
    $5 ? blower firewall cover
    SOLD ? heater core
    SOLD ? a/c inside condensor
    SOLD 90 325i Hvac wires, motors, cables and parts
    $5 ecu bracket and wire
    $5 black bracket
    $5 larger grey bracket
    $5 small abs cpu bracket
    $5 relay cover, driver front shock tower
    $2 passenger door triangle with broken tab
    $10 passenger door speaker with broken tab
    $5 door chime
    $10 90ix 3 metal, standard e30 headlight rings
    $10 90 325i rear shock mounts, covers and hardware
    $10 fan/clutch
    shift linkage? Will update later
    $10 90 325i late model left side 2dr window motor
    $15 88 325ix 88ix rear premium speaker shelf, ready for a respray
    $30 88 325ix Diamondshwarz Mettalic sunroof panel
    SOLD 88 325ix Sunroof fabric panel. Little dirty but very good condition
    $25 88 325ix 2dr grey passenger door panel and pocket. Great condition, no separation, no handle but a small piece missing at bottom
    $25 88 325ix 2dr grey driver door panel and pocket. Good condition, good amount of separation, no handle, otherwise good panel
    $10 88 325ix Trunk tool tray, clean
    $5 88 325ix glovebox left side trim
    SOLD 88 325ix 2dr rear body trim
    $5 88 325ix A-pillar trim, 1 broken tab each but otherwise good
    $5 88 325ix ebrake boot and trim
    SOLD 88 325ix cluster trim
    $2 88 325ix ebrake handle grip
    $5 88 325ix ebrake handle mechanism
    $5 88 325ix round gas tank cover, clean
    $5 88 325ix pill shape gas tank cover, clean
    $2 88 325ix interior light
    free 88 325ix vent ducts
    $5 88 325ix dash panel just below cluster, above steering column
    $5 88 325ix tire iron, a little rust
    SOLD 88 325ix ash tray and holder
    $2 88 325ix lighter
    $10 88 325ix driver side tail light backer panel
    $5 ? black module
    $10 ? blue plug ecu
    SOLD 90 325i heater valve
    $5 steering wheel top cover
    $10 90 325i 90 2dr passenger door wiring and hardware
    $5 88 325ix passenger side windshield vent cover
    $5 ceiling handles
    $2 88 325ix 1 hood receiver latch
    $15 mix seat belts (Converitble belts sold)
    $5 88 325ix 2dr rear window back trim with chrome. Both have paint scratches unfortunately
    $15 passenger door window motor and hardware
    $5 88 325ix e30 trunk latch
    $5 88 325ix e30 red lock actuator
    JUNKED afm
    $5 ? e30 red lock actuator
    $5 ? body trim, unknown application
    $5 ? trunk lock power mechanism
    $15 90 325i door wire harness
    $2 ? fuel rail cover
    $15 90 325i Late model passenger side window motor/lift (see the detail pic above for part number)
    $2 88 325ix hvac hose and valve
    $10 88 325ix a/c hoses
    $2 88 325ix radiator side trim around a/c lines
    $10 88 325ix power steering pump
    $20 90 325i brake master cylinder and reservoir NO cap
    $20 88 325ix power steering fluid cooler line
    $5 88 325ix driver side headlight backer plastic
    $10 88 325ix transmission brace
    $25 m20 starter
    $25 m20 starter
    $30 88 325ix a/c compressor comes with hoses and mount if needed
    $5 88 325ix a/c compressor engine mount
    $10 88 325ix a/c evap can
    $20 88 325ix abs unit
    $10 88 325ix power steering reservoir
    $20 88 325ix early body bumper shocks
    $25 88 325ix ix engine mounts
    $5 88 325ix steering knuckle
    $10 88 325ix ix oil dipstick tube, no dipstick
    $10 88 325ix rear wheel well fuel line cover. Rusty but usable, not eaten through
    $5 90 325i a/c compressor engine mount
    $10 88 325ix a/c condensor
    $20 88 325ix wiper motor and linkage
    SOLD 88 325ix ix rear stock springs. Car milage was 120k
    $5 tie rod boots, each
    $15 88 325ix spark plug wires
    $10 88 325ix m20 oil breather tube and spring
    $25 88 325ix ix specific front sway bar
    $50 88 325ix ix specific driver front control arm, bad ball joint, good CAB
    $5 88 325ix ix power steering reservoir mount
    $10 88 325ix ix specific car jack
    $20 90 325i seat belts
    $15 90 325i Calypsrot driver side mirror
    $15 90 325i kick panel for airbag car
    $5 90 325i ebrake boot, NO trim
    $5 90 325i steering wheel bottom cover for airbag car
    $15 90 325i headlight switch and trim
    SOLD 90 325i a/c panel trim
    $5 90 325i shift knob
    $5 90 325i side trim, unknown
    $5 90 325i driver door pillar trim
    50cents M30 Getrag 265 plastic pivot pin
    $5 90 325i e30 control arm boot cover
    $15 88 325ix non-airbag check panel
    $5 ? module
    GONE 87 325ic Delphin convertible top cover. Paint is good, tan cover needs to go
    SOLD 87 325ic Convertible top and frame. Good sewn in window but cover is worn at the hinges and should be replaced or patched
    SOLD 87 325ic Convertible rear interior panels. Good material to dye or recover it
    $5 ? Trunk trim piece, I think for convertible
    $10 90 325i Headlight bucket and rings
    $5 ? under engine rock guard
    $20 87 325ic abs unit
    $5 87 325ic 87 325ic auto front half of driveshaft with good center bearing
    $5 87 325ic exhaust manifolds, both need new studs put in
    $15 87 325ic power steering pump
    $25 87 325ic m20 starter
    $10 87 325ic steering fluid reservoir
    $10 87 325ic early body coolant tank and cap
    $10 87 325ic m20 auto flywheel
    $15 87 325ic 87 convertible, passenger window motor
    $10 87 325ic spark plug wires
    $15 87 325ic intake boot, auto I belive
    $10 87 325ic side marker. Someone repaired the usual crack and lense looks real good
    $10 87 325ic tool tray and a couple tools, broken screw
    $20 87 325ic abs computer
    $15 ? L style ICV valves, untested
    $20 87 325ic Delphin passenger side mirror, NO glass
    $10 87 325ic alternator needs to be rebuilt
    $10 ? And lastly, some coolant valve thing
    SOLD 87 325ic convertible specific seat belts
    SOLD 87 325ic rear speaker cover pair
    $5 87 325ic gauge cluster surround trim
    SOLD 87 325ic 13 button OBC and early model coding plug. Works but buttons are worn, lights are out
    $15 87 325ic CLS central locking system controller
    $5 87 325ic convertible rear view mirror
    $2 87 325ic convertible seat belt cover
    $5 87 325ic convertible top cover hinges
    e30, e39
    pm sent
    Sep 2009
    Burnsville?
    325ix 325ix 325ix 325ic
    I will take the vert seat and any vert trim you got.
    Apr 2010
    91 325i, 84 fj60, Ducati
    Do you have a radiator for an automatic? Or a front left ABS sensor?
    Minnetonka, MN
    E30 M3
    How's the paint on the Diamantschwarz sunroof panel? Hows the condition of the A/C HVAC trim panel? No breaks? I'll probably take both.
    Prior Lake, MN
    BMW 318ic (e30)
    I'll take the 3 headlight rings. PM Sent.
    This is a long shot but you don't have the spacer that goes under the nut that holds the steering wheel on do you? #4 in this diagram.
    Eagan
    pm sent
    Replied
    Quote Originally Posted by ejohnson View Post
    You're welcome to it. Email/pm me if you need my number again or give me a call anytime after 430 or 5 to be safe.
    Quote Originally Posted by slj333 View Post
    Sorry, I don't.
    Quote Originally Posted by aaronmjr View Post
    The paint is as near perfect as can be for the age, no rust or gouges. The hvac trim is ok but i think the sliders on the one i have left are shot. You're welcome to check them out any time. PM me for contact info.
    Quote Originally Posted by Tonys View Post
    Replied, forgot to mention that I do have a couple of those steering wheel rings lying around. You can have one.
    Thanks a lot everyone!
    Eagan
    Couple more parts added at the end.
    I'm home now and all weekend if you guys want to check out what you've asked for.
    Some parts are being picked up from craigslist leads this weekend so the sooner you can come by the better!
    Eagan
    Desperate for space and cash bump.
    Apr 2010
    00' 323i touring
    waow steve, you had more in there that I noticed! lol
    00' BMW 323iT -- 01' Toyota MR-S -- 08' 244cc scoot-puff
    84' BMW 325e/5 24V in progress
    -- 92' BMW 850i/6 -- 97' BMW M3/2/5
    Eagan
    I thought you saw my basement...I did strip another car last year since the last time you were here though. Haven't been able to remodel or even use my basement since I moved here.
    Apr 2010
    00' 323i touring
    sheesh! haha.
    and I thought I had a problem :p
    Aug 2008
    Mason City, IA
    1989 BMW 325I
    What do you have for Diffs? I'm looking for 3.25lsd or 3.73lsd to replace my 4.10open in my 89 325i.
    Do you have a crank sunroof/visor panel?
    Also I could probably use that 3 hole center console as well.
    Flickr @michael_colby on instagram
    Eagan
    I don't have any diffs or visor panels but you're welcomed to the console though.
    PM coming
    Quote Originally Posted by vwmichael View Post
  1. 1989 325i - 95% Rust-Free - No Title
    By hi its me alec in forum Cars Classifieds
    Last Post: 12-29-2010, 08:26 PM
  2. FS: 91-93 325ic lower from apron (nearly free)
    By JTapper in forum VW-Audi Parts Classifieds
    Last Post: 05-30-2010, 04:46 PM
  3. FS: Random OEM Mk1, Mk2, Mk3, & Mk4 Parts + Free Stuff
    By VinDiesel in forum VW-Audi Parts Classifieds
    Last Post: 05-20-2010, 11:32 AM
  4. FREE or almost free parts- Cabby, Scirocco and 16v stuff!
    By Ffejtech in forum VW-Audi Parts Classifieds
    Last Post: 10-09-2009, 05:45 PM
