Results 1 to 15 of 28
    Dec 2007
    Edina
    328is Super Coupe
    Default How to do an exterior detail without sucking
    I've been putting this thread off for a long time and since I now sit here with nothing to to this weekend, I figured I'd put this together. The point of this thread is to give you a step by step idea of how to properly detail a car. I did not buff my car, so that is one huge step that is not included in the photos, but I will explain further about it.
    I'm a detailer professionally, I have worked on some very high end vehicles and just about everything that has been made in the past 10 years. Which is why I have a kickass setup a work. Buying this kind of stuff on a smaller scale would be pretty expensive. But I will try to explain things as if I was doing this at home. FYI, I do not own any of my own equippment. And, no, I will not detail your car. I took all the pics myself with my phone, so they don't look great and some are pretty shaky.
    Back on Friday June 24th, I detailed the exterior of my car for Eurowerks V. I spent about 6 hours on the exterior, half an hour washing, and half an hour vacuuming the interior and doing the windows. So it was about a 7 hour deal, from about 6:15p-1:30a. Yes, to do a good job detailing you need to be really anal. That's just how it works.
    Step 1: Washing
    This is an obvious one. Hand washing is a far better way to get the car clean for two reasons: 1) the wash mitt picks up crud that a touchless sprayer just doesn't get, and 2) if your mitt is cleaned properly (or new) then you don't have to worry about putting in scratches that a typical gas station slap-n-scratch wash will so kindly do.
    I always presoak the car in degreaser as it will start to eat away at things like brake dust on your wheels, excess dirt/dust on the paint, etc. It's already soaked in this photo. After that has sat for a minute or so, I powerwash it all off, making sure to spray out the door/hood/trunk jams as well as the side mirrors, and wheel wells.
    Many people will need to get off the caked on and black/brown brake dust. They make special wheel cleaner that is often acidic. That stuff normally works very well. Use a stiff bristle brush to work it in. After a little bit with some elbow grease the brake dust will be mostly, if not entirely, gone. Leaving you with a wheel that looks like new.
    I put in fresh water and soap and spray off the mitt to clean it out. So everything is fresh and good to go.
    All soaped up. I typically soap the car in the following order:
    Top painted surfaces (hood, roof, trunk)
    Sides ABOVE the trim
    Front bumper
    Sides BELOW the trim, but above the rocker
    Rear trunk
    Rear bumper
    Rockers
    Glass
    This is all for what is visually important to the car. The top surfaces will suffer the most in the end result from any scratches put into it by the wash mitt. So I start where I need it to look the best. If something gets picked up by the was mitt, it may scratch, but it will be in a place that isn't as noticeable. So I go from most important to least important scratch-wise.
    I make sure to get everything that could hold suds with the water. We have a Hosty at work, so this water sprays at anywhere from like room temp to 240 degrees. We have it set to about 150.
    Now that the car is mostly dry, I can bring it inside to start the detail. It has now been a half an hour since I started the project. I use one of those California Car Blades to speed up drying the car off. It whisks the water off the paint and works well. People think that they'll scratch your car...they will...if your car is not clean. Since I just spent a half hour washing the paint, I'd say it's pretty clean.
    Step 2: Drying the car throughly
    Because the car has just been washed, there is still plenty of water hanging out in crevasses, jams, etc. So I take the compressed air hose to all the corners, edges, whatever to blow out all the remaining water.
    *Actually* dry.
    Step 3: Initial inspection of the paint and surfaces
    Here is what I start with. Keep in mind that because I am a detailer by trade, I do keep my car fairly clean. So I don't have any major scratches to speak of. But I do have plenty of other imperfections I want to address. I have 6 and a half more hours of fun so I have my work cut out.
    But before I can buff, there are a few crucial steps you MUST take in order to not only achieve a better result, but prolong the life of your pads. You need to clean the paint further.
    Step 4: Fixing plastic trim
    First, I take an eraser (just a regular eraser) to the black plastic door trim to get rid of as much gunk as possible. Dried on wax, buffing compound, burn from buffing...it turns white and ugly. An eraser normally takes care of it I've found.
    Step 5: Solvent wipe down
    Now that I've taken care of the trim, I can start to soak down the car in a solvent. This does two things, it breaks down any greasy substance that may be on the paint (road tar, grease, etc) and lets you wipe it off. The other reason is that it kind of acts as a final wipe down of contaminants on the paint. I wipe the whole car top to bottom.
    As you can see, I pulled up a bit of tar. The most common spots to find that is right behind both wheels front and rear, and on the vertical face of the trunk. Just like salt spray on cars in the winter.
    Step 6: Claybar
    Now I claybar the whole thing. Using a spray wax as lubricant, I wipe the clay across the paint in a constant speed/motion. This will pick up the harder to remove things, such as really tough dried on tar, bugs, overspray, whatever. Pictured is a place on a car that is a usual bad spot...right behind the front wheel.
    I didn't pick up a whole lot of stuff, the solvent got the majority. However, most cars I work on are worse since the people aren't keeping their cars as clean as I try to. When a piece of clay gets dark, you should fold it over ad start with a fresh side. You can do this many times before the chunk of clay becomes worn out. It has not been about a half hour since I brought it inside from the wash.
    Step 7: Taping
    I spent about an hour taping off every piece of exposed plastic and rubber with 3M masking tape.
    Step 8: Buffing
    Like I said above, I did not buff any part of my car as there was no need to. But when you buff, you need to follow roughly the same techniques you'd use when polishing (I will be referring to it as "foaming" below, because it uses a foam pad). The biggest issue with wool buffing pads is that the fibers will cut too hard and create circular cuts in the paint which is just about my least favorite thing ever, because they're a PITA to get out. Cleaning your wool pad is priority. If you have a spur or something you can use to periodically clean the compound out during use is a good idea, that way the compound doesn't cake up in the pad. If that happens, the pad will not cut as well.
    To remove a scratch with a rotary buffer (I use a DeWalt), you should always start slowly and without much pressure until you get a feel for what the paint need. This is absolutely an aquired skill. But putting more pressure on it will heat the paint up and actually start to melt the clear coat to the point where the scratch will start to fill itself in. This is all done while moving back and forth at a constant speed.
    It is very difficult to describe how to buff in text, it is really something you must see to learn.
    Step 9: Foaming
    Well this is normally done after buffing, but I knew that most of the scratches in my paint I could get out with a foam pad. So I jumped right to this step.
    If you notice, you'll see concentric circles, this is the compound from my pad that was left when I finished foaming this area. The light I am shining onto the paint is called a Sun Gun, made by 3M. It replicates the suns light to help me see things in the paint (such as swirls) that artificial lighting doesn't expose.
    But note that I use a side to side motion with a 50% overlap. I do 3 passes per section. First pass is left to right with a high amount of pressure, The second pass is up and down with medium pressure, and the third pass is left to right again with light pressure. This is to eliminate as many swirls as possible.
    I use that yellow pad on the whole car, then do the same thing again with a softer pad to eliminate any cuts or swirls left behind by the yellow pad. All wiped down with a new microfiber towel.
    Step 10: Waxing
    Most people will use a paste wax and an applicator pad, or a liquid wax and rub it on by hand with a microfiber. That all takes too long, so I use a liquid wax on a soft foam pad with the orbital to apply wax. This option benefits me twofold: 1) It takes a fraction of the time to apply wax to the whole car, and 2) with a orbital motion, it helps to fill in any faint, remaining swirls.
    1/2 wiped off.
    Finished result. We are now several (like 4.5-5) hours into the detail.
    Step 11: Wheels
    Everyone has different wheels. Mine are polished aluminum two piece BBSs. After washing the car, they're free of dirt for the most part, so the only thing I needed to do was polish the barrels. I took liquid metal polish and polished each one twice. Then when I had done that, I took a paint sealant and let that sit one each barrel for a minute and wiped it off. Paint sealant will seal protect anything, not just paint.
    This was after the first pass.
    Step: 12 Finishing
    Pull the tape off, wipe out every jam with a towel and blow all the dust off the surfaces, jams, windows, etc. I put a plastic/vinyl/leather care cream on the tires instead of greasy tire shine (at least in this case, tire shine goes on every car I do at work otherwise). I like it waaaaaay better becaue it doesn't have a wet shiny look. It just looks like a nice and clean tire. I used the same stuff on all of the plastic and rubber that I had taped off earlier, to give it an extra little pop.
    Wipe down the windows and clean the tailpipes and you're pretty much golden.
    So I may have spent 7 hours in this case, but I'm super picky with my car. I normally wouldn't even spend half that time on just an exterior of another car.
    Hopefully you learned something and have a better understanding of what goes into a half decent detail. And remember...TAKE YOUR TIME!!!! DON'T RUSH!!!!
    Vadnais Heights
    82 Rabbit, emkayfour
    Wow, excellent write up.
    I never thought an eraser would "erase" white wax build up on trim. Who woulda thunk?
    Thanks Kyle.
    sǝɹɐnbs ǝɥʇ ǝʌɐs
    I can attest to the size of the nuts.
    Aug 2011
    1989 BMW 325i
    I'm being a bit nit picky, but it sounds like you said that with a rotary buffer you are to try and melt the clear coat to fill in the scratches?
    Awesome! Thanks Kyle!
    FYI: this advice might work in the bedroom too
    Dinky
    73 Opel GT, 540i Msport
    yay kyle FANTASTIC write up
    I almost said a curse word!
    Dec 2007
    Edina
    328is Super Coupe
    Quote Originally Posted by smartamar11 View Post
    That is essentially correct. This is reference to deep scratches, light scratches will be taken out by the cutting action of the wool buffing pad.
    For deeper scratches, the wool pad not only removes a small amount of clear coat, but as it heats up the metal surface beneath the paint, the clear coat will begin to melt and that will help fill in the scratch. The "melting" is very minor, as I do not allow the pad the get one area too hot.
    I will use the layout of a regular clock to explain. The buffer spins clockwise, so:
    At the 12 o'clock position, the pad is moving from left to right.
    At the 3 o'clock position, the pad is moving downwards.
    At the 6 o'clock position, the pad is moving from right to left.
    At the 9 o'clock position, the pad is moving upwards.
    So say you have a deep scratch 3" long that is mostly horozontal. If there is any point at which you can fit your fingernail in the scratch, it is typically too deep to remove completely. It can be lightened, but chances are it will not go away. In this case, I start out with a wool pad dedicated to a heavy cut compound (I do not cross contaminate pads with different chemicals). This is a more aggressive compound than I normally use to buff with.
    I start by spinning the pad to spread the compound out evenly over the area surrounding the scratch. with my pad, I will put pressure on either 3 o'clock and 9 o'clock positions. Because the scratch is horozontal, and the spin of my pad is up/down, I am maximizing the effect of "melting" the clear coat and paint to fill in the scratch as best I can. Each end of the scratch is going to be the lightest, which makes the middle the deepest part. This is the case in almost every deep scratch I find. As such, the middle part is the only section that remains somewhat visible after I've worked on it.
    After I am confident that the aggrssive cut compound has done it's job, I move to my standard buffing compound on its dedicated wool pad. This is the exact same idea as sanding, if you use a heavy grit sandpaper, you must use each step above it to get the surface smooth. In buffing, you replace the "smooth" with "swirl free". After my standard buffing compound, then I move to polishing with a medium coarsness pad (the yellow one in my wirte up), and then a soft pad (the black one).
    Foam pads in their own right heat up the surface faster than a wool pad, so I am actually able to foam pad many scratches out when some people would need a wool pad to remove them. It's all in the tecnique.
    E39/E91/LRDII
    I'm sure Kyle knows this. But just as a general note...be very, very careful trying to move clear coat around. From car to car the clear can behave very differently. On one car you might make a light scratch disappear, on another you might move the clear waaaaay too much and fuck up the paint with the same amount of time and pressure. Probably not something you want to try on a nice car if you've got limited experience
    Oct 2007
    1992 Volkswagen Corrado SLC
    Many people recommend using the two bucket method to ensure that you have a separate soap and rinse bucket (keeps the wash mitt even cleaner). Is there a reason that you don't?
    Oct 2009
    St. Paul
    '89 Golf GL, '91 GTI VR
    very nice write up.
    Dec 2007
    Edina
    328is Super Coupe
    Quote Originally Posted by JK9K View Post
    This is very true. New cars all have pretty soft paint, but your typical 10 year old car will have pretty hard paint.
    Cars with soft paint would be Honda/Acura, Toyota/Lexus, BMW, Mercedes, VW/Audi.
    Cars with hard paint would be like Subaru, Ford, GM, Nissan (to some degree)
    Those are just examples. You don't want to try to tackle a tough scratch if you're not very familliar with how paint on X car will behave. When a section has been repainted then it's kind of all up in the air. And if you're not familliar with using a rotary buffer, I wouldn't recommend you trying to do it yourself because it's super easy to fuck up your paint with a rotary if you don't know exactly what you are doing. I've been using them for more than four and a half years and I'm still learning new tricks.
    Quote Originally Posted by corradoxs View Post
    The reason is that you don't want specs of junk floating around in your clean water and getting back on the mitt. That's the idea, anyways.
    If you notice the second bucket in the bottom right corner of the photo, there is a red webbed looking deal. That is to catch and hold particles that sink to the bottom. It keeps water from swirling around at the bottom so the junk stays put once it's there. So it essentially negates the need for two separate buckets.
    We still have two buckets, but that is because one is for new cars and one is for used cars. Each has it's own dedicated mitts. This is so that new cars don't get scratched up with crap that came off of some used car previousy.
    Great stuff!
    I would like to here your thoughts on specific products. You mentioned using a degreaser, and a few other things... what products do you find work best, or what should we look for/avoid in the products we buy?
    For instance - a lot of detailers thing Armor All is bad, presumably because of the silicone and greasy feel... any other thoughts?
    Cakeville, MN
    GTI3RS v4.0Cali.Ltd Turbo
    Quote Originally Posted by Die Frau View Post
    This x2, also what kind of products in regards to microfibers and wash mitts.
    If the women don't find you handsome, they should at least find you handy.
    ~Red Green
    Jan 2008
    MPLS
    GTI, 100Q, 200Q 20v
    Would you mind elaborating on how you apply the painter's tape? Yours seems immaculate, with no overlap.
    Fingers of butter, fists of ham.
    Dec 2007
    Edina
    328is Super Coupe
    Great stuff!
    Well, I use mostly Car Brite stuff which works well for me. Their degreaser, soap, solvent (called All Sol), window cleaner, interior cleaner we get in 5-gal containers.
    3M makes a lot of good stuff, Joey uses their Black Pearl line of comounds and he loves it. I think we went with Meguiar's because it works well but may not be as expensive. I could be wrong however. I don't recall using anything made by Mothers, but I've heard they have some good stuff as well. But I would stay away from anything made by Blue Coral, their entire line was garbage a few years ago and I have no reason to believe it isn't still now.
    Armor All is kind of a cop out as far as interior detailing goes. There are pretty much two camps of detailers when it comes to interiors: people who like clean and dry plastic, or "clean" and shiny plastic. I'm the former. I absolutely hate having a car come in with the dash all greasy. I commonly refer to that as "Gucci Shine". Lots of cars come in all Gucci shined up and it's a pain in my ass because I not only have to get that stuff off, but it also collects dust like a muhfugger.
    Now, I do clean the black plastics with a non-greasy cream we have (door sills, pedals, center console, etc). But I rarely will use it on the dash. There have been times when my only option to make the interior look half decent was to Gucci shine the shit out of everything. But those cars are few and far between. And I don't like having to send it out looking like that.
    Basically, it just looks super half assed. But that's just my opinion.
    Quote Originally Posted by MisdemeanorMatt View Post
    Clean ones. There really isn't a whole lot to microfibers or wash mitts. But lambswool wash mitts will be much softer than your regular foam pad. Using a shamois towel is also good so long as it's clean. They work really well for drying the car, too.
    Quote Originally Posted by Aladinsane07 View Post
    Very carefully. Just take your time. That took me an hour to do, using both 1" and 2" width tape. I've seen lots of bad tape jobs, but that's because the person didn't want to spend the time to get it right.
    The whole thing about detailing is take your time. If you screw up with a line, just redo it. Tape is cheap.
    Aug 2011
    NewHopeMN
    05 GTI... Was stock
    Id really like to know what products you are using at each step if at all possible... or a recommendation as what to use
    Owning a VW is like having a hot girlfriend that's mentally unstable
  1. Looking for an exterior building painter
    By Turkish in forum Labor and Job Networking
    Last Post: 06-22-2011, 06:31 PM
  2. Various B5 A4 1.8TQ Interior, Exterior, Performance Parts
    By Midw3st_dubn in forum VW-Audi Parts Classifieds
    Last Post: 06-19-2011, 02:22 PM
  3. FS: Random Mk3 Exterior Parts
    By Ventodub in forum VW-Audi Parts Classifieds
    Last Post: 08-23-2010, 09:24 PM
  4. Anyone need Painting Interior/Exterior
    By MPLS MK3 in forum Labor and Job Networking
    Last Post: 01-23-2009, 09:54 AM
  5. Eurowerks Promotion- Full Interior/Exterior Detail $120
    By Philosomatika in forum VW-Audi Car Classifieds
    Last Post: 06-13-2008, 02:33 AM
