Page 17 of 22
FirstFirst ... 7 13 14 15 16 17 18 19 20 21 ... LastLast
Results 241 to 255 of 321
  1. #241
    Dinky
    73 Opel GT, 540i Msport
    yeah, thats why i have been having ravenworks coordinate everything for me. i would f***ed if i was doing this myself
    I almost said a curse word!
  2. #242
    Sounds like you had the crank polished and used standard bearings.
    The bummer of that is that you have to install the bearings in the mains, mic them, then mic the crank journals and find your clearances.
    The home method, and mostly foolproof, is to use plastigauge once the crank is installed and the main caps torqued to spec. Either way, once this is done the bearings are considered used and are now pretty much a wasted part. There really is no way to know ahead of time though, unless you mic all the journals before and after, and have all the factory dimensions available.
  3. #243
    Dinky
    we actually had to cut the crank a bit but yeah. it has been 5 years since i have built an engine so i am just letting the people who know what they are doing take care of it
  4. #244
    Dinky
    bought myself a quick release hub at the swap meet today (thanks paul) and couldn't wait to put it on so i went down to the shop and installed it. the wheel is really close to me now which i like.
  5. #245
    maple grove
    mk3 jetta
    lookin good! im guessing this will be ready for EW6?
  6. #246
    Dinky
    here's hoping... but yeah i would like it to be there but we will see what happens with the motor
  7. #247
    Dinky
    parts came, they sent the wrong freeze plugs, does;t really matter since they weren't going in till the crack and head gasket were sorted anyway. also got a set of poly balljoint and tie rod caps, a new front leaf spring, and some steering rack boots (one was torn). the main event though is the new ceramic coated header
    it came with another flange attached to some tube so that will help with exhaust costs and the welds look like they had a lot of penetration. I love the way it looks but i am going to wrap it and probably make a heat shield so you won't be able to see it much... i can't wait to hear what it sounds like!!!!
  8. #248
    337, '98 Jetta GLX
    Do you really need to wrap it if it's already ceramic coated?
    Quote Originally Posted by 9jetta6 View Post
    Oh dang it does look like its chopped in the back there. Clicked on the link, if its actually legit and can run good, looks fun.
  9. #249
    Warren, MI
    50mpg double wishbone
    Quote Originally Posted by Majend View Post
    It should be there even if it has to come on a trailer!
    That exhaust is sexy. Can't wait to hear it. Maybe I missed it but what is the ETA for the engine?
    and mesmerizing. Ive never considered how much those balls move about until now.
  10. #250
    Dinky
    Quote Originally Posted by JUSTION337 View Post
    since the carbs are over the headers i think i am going to do it.
    Quote Originally Posted by Sven7 View Post
    don't know, can't order the head gasket till the crank is sorted out and we don't know how backed up that shop is...
  11. #251
    337, '98 Jetta GLX
    That's right, I forgot about that.
  12. #252
    Why can't you order a head gasket until the crank is sorted? That doesn't make any sense if you're using the stock crank and didn't take a ton off the head or block.
  13. #253
    Dinky
    i went high comp with my pistons. i may not be describing the reasons properly
  14. #254
    ravenworks should be able to know what the clearances are based on the new deck heights, stroke, rod length and piston crowns.
  15. #255
    Dinky
    which is why i am just letting them handle it.
  1. f/s vette rims 17x9.5
    By tattoo-freak in forum Wheels and Tires Classifieds
    Last Post: 09-23-2010, 05:46 PM
  2. WTB Red (but maybe black) Vette Convert
    By alpineE30 in forum VW-Audi Car Classifieds
    Last Post: 07-02-2010, 11:19 PM
  3. Replies: 17
    Last Post: 06-15-2010, 11:08 AM
  4. FS: Vette Sawblades *Staggered* (5x120)
    By Ventodub in forum VW-Audi Parts Classifieds
    Last Post: 05-08-2009, 10:06 AM
