So as some might know, I blew a rod through my block leavin eurowerks!!!!!!! So I'm tryin to figure out what to do next. I'm seeing if anyone has a good deal on a awp motor or if I should go a different route. Let me know if you got something!
thats what the tow truck was for, shitty.. what motor was in it when that happened?
Team B0N4R
is the crank still good? I need the trigger wheel!
im sure the crank is good. the motor was a 1.8t
how much for the crank sensor trigger wheel off the crank?
I have a bunch of 1 8T parts including block rods pistons, however this is amb longitudinal motor so not sure if it would fit you.
Otherwise I might be interested in the head depending on how much you're looking to get for it
chris do you have a picture of the part you're looking for?
Its something like this. its bolted right to the crank between the crank, and the place where the pressure plate mounts to the crank/block.
alright. im kinda looking for like....tomorrow. so let me know.
ok, I don't have that. I have an auto crank and I'm not sure that' the same
