Results 1 to 7 of 7
    Apr 2010
    00' 323i touring
    Default E30/E36/Z3 Control Arm Bushing (Lollipop) replacement.
    E30/E36/Z3 control arm bushing replacement (Lollipops)
    Tools you’ll need:
    1.) Floor Jacks
    2.) Jack stand (recommended for safety)
    3.) ½” drive ratchet
    4.) 1x 3” extension for said ratchet
    5.) 17mm shallow socket ½” drive
    6.) 19mm shallow socket ½” drive
    7.) 22mm shallow socket ½” drive
    8.) angle grinder with cutoff or grinding disc
    9.) chanel locks
    10.) 2x 12” all thread 5/16” - 18.
    11.) 4x 5/16” washers
    12.) 4x 5/16” -18 nuts
    12.5.) a 6” section of ⅜” square metal stock
    13.) a 3 jaw gear puller. I bought one off of Amazon.com
    14.) a Harmonic Balancer puller (I bought this on amazon too. basic is fine.)
    15.) new lollipops
    Shall we begin?
    Step 1.) Jack up the front of the car, I used two floor jacks, one on either side.
    Step 2.) locate the lollipops, and the two 17mm bolts that hold them to the underside of the car.
    Step 3.) remove and set aside the two 17mm bolts and washers from the lollipop.
    Step 4.) Position your 3 jaw puller around the lollipop and once seated firmly, tighten the 17mm pusher on the tool until the old ring and outer rubber bushing pop out.
    Step 5.) take your angle grinder and notch the remaining rubber and metal part of the bushing all the way down so you can see a layer of rubber, a layer of metal and another layer of metal
    Step 6.) once you’ve gotten to the inner rubber, use your chanel locks to rotate the remains of the bushing 180 degrees and repeat step 5.
    Step 7.) once you have your two nothces, the metal part of the bushing should fall right off. the remains will be a thin rubber sleeve and that will slide right off with the help of your chanel locks, or a gloved hand (its VERY hot.)
    Step 8.) push the new Lollipop on to the control arm as far as you can by hand, then position your newly created tool (harmonic balancer puller with thread rods, metal stock, washers and nuts) through the control arm and around the face of the new bushing.
    Step 9.) put your 22mm socket on the face of the bushing, around the hole where the control arm end will come through. place the pointy end of the pusher section of the balancer puller in the drive hole of the socket.
    Step 10.) KEEP YOUR TOOL STRAIGHT! and use the 19mm on the end of the puller to push the new lollipop onto the control arm.
    step 11.) re-install the two 17mm nuts and torque them to 55 lb/ft. (or just guess, but pretty hard.)
    step 12.) repeat all of that on the other side, and you’re done!
    00' BMW 323iT -- 01' Toyota MR-S -- 08' 244cc scoot-puff
    84' BMW 325e/5 24V in progress
    -- 92' BMW 850i/6 -- 97' BMW M3/2/5
    duluth
    old passat wagon.
    nice writeup!
    also, good advice:
    Quote Originally Posted by 2.5-12 View Post
    Quote Originally Posted by Driv3r View Post
    Look man don't start talking shit!
    Jun 2010
    Saint Paul, MN
    2010 Mazda3 GT
    RE: Step 4
    When I did these the rubber was too beat up to get the whole thing off with the puller. The floppy bushing would angle and the puller would slip off. You can "carefully" use a sawzall to cut through the rubber, leaving just the center metal ring on the CA. You can then use the puller (a smaller 3-jaw) to get the inner ring off the control arm.
    If you want to reuse the lollipops, you can cut through the outer ring of the bushing with a hack saw, dremel, or other thin metal-cutting saw and use a cold chisel to collapse the ring. Pops right out if you do that.
    Apr 2007
    Lauderdale, MN
    lolvo
    You make that look hard, I've always just hosed 'em down with PB blaster or whatever I have handy, twisted 'em and pulled 'em off...
    Let me guess, profuse masturbating?
    Apr 2010
    00' 323i touring
    I bet it took longer than this did, though.
    40 minutes start to finish with no headaches.
    the right tools make all the difference.
    Mankato
    2009 VW CC Manual
    you can also just loop a tow strap through the holes on the control arm and then push the bushing on using the jack out of the trunk. When you get to the end of the arm just use a big socket. That is how I go them back on.
    Apr 2010
    00' 323i touring
    fair enough, I just tried to reduce headache.
  1. Replacement key fob for an A6
    By Mar48 in forum Technical
    Last Post: 06-14-2010, 08:00 PM
  2. The 9-3 replacement.
    By palmer in forum Non-Euro Automotive Discussion
    Last Post: 06-08-2010, 08:39 AM
  3. Oil pan replacement.
    By Jakeb5 in forum Technical
    Last Post: 06-05-2010, 08:58 PM
  4. FS: 1 OEM e30 Subframe bushing - $5
    By MechE30 in forum VW-Audi Parts Classifieds
    Last Post: 05-28-2010, 11:31 AM
  5. mk4 vr6 alternator replacement
    By veedubmechanic in forum Volkswagen/Audi DIY
    Last Post: 11-16-2008, 11:23 PM
