Results 1 to 11 of 11
    SSP
    '91 Audi 200 20v Avant
    Default 2001 Pontiac Grand Prix GT Stalling issue
    My wife's car has been giving her some problems recently... a few harmless stalls... But today it stalled in an intersection and that's enough for me...
    It seems as though the majority of the times it stalls (it's only been a handful) it's from coming to a stop after driving.
    3 times while parking... once while coming to a stop turning right at a red light.
    At least 1 or 2 of the times I can tell you the tachometer stopped responding briefly, then it stalled... Does that point to the CPS?
    Anybody have any other ideas? I'm going to run it for codes but it's tough because she needs it to commute to work
    Thanks in advance
    -Drew
    New Ulm MN
    Obscure Vehicles Inc.
    scan it, ODBII is a fandangled thing
    SSP
    yep... will do (mentioned that in the OP) but she works long hours and just figured i'd toss this out there as a hail-mary (maybe someone has dealt with the exact symptoms)?
    Twin Cities
    91 E30 Alpinweiß II
    I have a 2001 gtp and never heard of this problem. Does the cel come on? I vote scan it to, see what it says. Maybe the fuel pump is going bad?
    SSP
    Unfortunately the CEL is burned out! It has had a harmless emissions code since highschool. Haha. (she's 24 now) But I'll figure out more (hopefully tomorrow) when I scan it.
    if I get my vagcom cable back this week I can scan it for you.
    May 2009
    Hudson, WI
    B6A4 Avant, '90 CQ, Tahoe
    Coming to a stall after driving immediately makes me think that the torque converter is not releasing like it should be when you're coasting to a stop.
    New Ulm MN
    if it were a grand am and not a grand prix i could give a whole list of things that could be haywire. however since the 3.8 is a superior engine over the 3.4 i have no clue past electronics issues (i know there were several electronics issues pontiac suffered from between 2000-2004 that involved tach signals dropping along with dash power and engine stalls). check some recall sites, i know my mrs grand am in the past went in for a couple and if they extended to the grand prix there may be a free fix waiting at the dealership.
    Quote Originally Posted by Dwalmop View Post
    I had a cutlass that did this. It was a pretty violent stall, and the TC would not release unless parked for at least 15 minutes. Drove it around like that for 6 months until the neutral drops finally killed it.
    1990 Cutlass Calais. 345k miles.
    Rochester
    04 jetta wagon, 12 Golf T
    pull the engine cover off and pull the vacuum line off the fuel pressure regulator and see if there is fuel in the vacuum line.
    Nov 2009
    jetta
    your post doesnt say anything about the engine size, so i will throw out a few things....
    if its the 3100 or 3400, check the Fuel Press Reg as mentioned above. it is also possible that the lower intake gasket is toast and is causing a vac leak. your MAF sensor also may be shot.
    if you have the 3100, you have the 4t60e transmission and therefore, it is vacum regulated. it is POSSIBLE, but unlikely, that the vac modulator on the front of the tranny is toast. more than likely, if the problem was the tranny, it wouldnt die, but the trans would have some SUPER hard shifting or no shifts at all.
    i dont think your trans or Torque Conv is the issue.
    if its the 3800 (non SC), my guess is MAF or if you have the plastc upper intake, its possible that the heat from the EGR location has cracked/warped the upper intake causing a vac leak.
  1. Pontiac: RIP
    By mimalmo in forum Non-Euro Automotive Discussion
    Last Post: 04-28-2009, 09:50 PM
  2. Did the gran prix finally get put down?
    By audivwdave in forum Euro Automotive Discussion
    Last Post: 09-01-2008, 10:26 AM
  3. Some pontiac guy..
    By audivwdave in forum Spottings
    Last Post: 07-19-2007, 10:49 AM
  4. Pics from the Montreal Grand Prix
    By TylerC4S in forum Euro Automotive Discussion
    Last Post: 06-21-2007, 04:01 PM
