blinking engine light in the mkII vr![]()
blinking is bad.
It is not that you CAN'T, it is that you don't know how..... YET
only drove about 20 feet.
weird... does every sensor come over with the swap? Did you check the coil pack?
coilpack is new. I didnt check it. why check it when you can just scan the car?![]()
cause you don't have a vag comWhy not check a coil pack when all you need is a little water... I was only asking about the coil pack because it rained today.
aware. lazy.
you can pee on it too... that works.
ODBI or ODBII?
i got the obd1 and 2 vag com... lmk pm
obdII
either way I have a vag-com and all cables..![]()
bad coil pack. replaced. runs mint.
