I blew the turbo on the engine and I want to replace it with a new turbo since this one was just rebuilt. I am planing on replacing the injectors/fuelpump with new hi flow ones since I need to get a tune anyways. I was thinking a k04 if it would work since I would like to get a little better performance but nothing crazy.
I do not know what turbos would work for it, perferably bolt on. I already have a techtonics downpipe, forge diverter, and ECS 75 valve. I am planning on getting a cold air intake at the same time.
However it was a AWP swap into a 2001 GTI and is still using the 2001 wireharness and 2001 ECU. I can not connect to the computer via a VAG-com so I do not know if I am going to have to replace the ECU with a newer one, and if I would have to fo a new wire harness at the same time.
Just bought the car and am working on making it fun and reliable at the same time.
