Originally Posted by
sgt snuffles
seeing as how the pad is only about 5" its gunna be tough to use, being that you greatly reduce the risk of burning your paint since you more focused on just a small spot since the pads so small... id recomend picking up a makita buffer and a wool pad and polishing pad with cutting and polishing 3m ive used it for years comes out great
i agree on the majority of that....only thing that i would keep people, learning how to buff, away from is the wool pads. Chance of burning the paint with a wool pad is greater then a white foam pad from 3M..not to mention how much easier it is to put in swirl marks...just my 2cents though
20psi + Functional air to water IC = 308whp/290wtq
26psi = ??
BF! built - Revo Tuned
