Results 1 to 9 of 9
    Champlin
    01 Rave Green 1.8T GTI
    Default Misfire maybe coil or plug
    When I accelerate the car hesitates and kinda sputters w/ the cel flashing. So I'm pretty sure it's a misfire, but not sure if it's from a plug or coil, and which cylinder it's coming from. How can I know for sure?
    Nov 2005
    St micheal, Mn
    2011 Jetta Sportwagen TDI
    Quote Originally Posted by sheriff View Post
    Get it scanned. We can do this at the shop today. Just give call. Also I keep the coil packs in stock.
    This sounds like a coil pack.
    612-722-8897
    Chad Erickson
    SCI Performance
    612-722-8897
    Chad@sciperformance.com
    http://www.eurowerks.org/image.php?u=316&type=sigpic&dateline=1195628404
    MK2 VRT B5 A4 VRT
    chad is the man
    hello friend
    indeed
    stuff
    Sounds like a coil pack. My #2 went last week. Call Chad!
    Jan 2007
    Hudson, Wi
    '03 2500HD, 01 A4, 02 TT
    Water bottle in the dark test.
    lol water bottle in the dark lol... dont think that would work too well on a 1.8t
    autozone scans check engine lights for free, it will at least tell you what cyl is misfiring (if there is only one. maybe have 2-3 misfiring/??)
    Richfield, MN
    01' Jetta, 91' GTI
    Quote Originally Posted by veedubmechanic View Post
    You can also pull the coils one by one to see which one is misfiring. If you hear a change in idle you pulled a working coil. If you pull the coil and it doesn't change then that is the one that isn't working. Just change it out and you're be good to go (till the next one goes anyway).
    On the subject of crappy coils I converted all of mine to the "e" style when my last one blew. These are the bolt down version which apparently are better quality and last quite a bit longer.
    You can also pull the coil out, put a screw driver into it where the plug would connect, then start the car.
    A good coil will arc between the shaft and the metal shielding around the side. A dead coil will not arc.
  1. Project: PITA
    By tima in forum Project Forum
    Last Post: 04-05-2011, 08:47 PM
  2. Replies: 4
    Last Post: 10-30-2008, 05:22 PM
  3. 1991 VW Corrado G60 Coil Issues
    By Jon Palzer in forum Project Forum
    Last Post: 07-23-2008, 07:17 PM
  4. 16V plug wires - SCI - barely used $50
    By shanetrain in forum VW-Audi Car Classifieds
    Last Post: 03-07-2008, 10:32 AM
  5. Sporadic Misfire
    By ScottP in forum Technical
    Last Post: 08-19-2007, 11:36 PM
