So I have a collection of parts I need to clean out. Too many piles of stuff in garage and I need room for summer tires when I mount my snows. I can ship if your not local, just pay for shipping charges (usually under $8.00) Most parts are test parts or off my own car.
MK4:
2.0L cam sprocket with good cam sensor wheel (I believe aeg? not 100% on that)
$40
"F" revision n75 valve 1.8t, works great no issues OEM
$40
Aftermarket "E" revision n75 stock 1.8t, dont know if it works, was a warranty part never installed when I got the new one
$20
Large hole Map sensor for 1.8t, works great
$20
Stock g/j/b sidemount intercooler, works great
$40
SAI pump, all hoses airbox to pump, pump to combi valve, works great no leaks no ck eng light.
$100
SAI combi valve, works great, 1.8t
$40
SAI solenoid valve, bracket, hoses, n249 solenoid valve
$60
Forge 007/008 green spring (came with my rebuild kit)
$pack of beer or club donation
B5 passat/audi 2.8/2.7
Throttle body for 2.8, came off core engine
$40
Throttle body off passat/a4 1.8t
$40
Full Auto trans service kit: 7L of VW Pentosyn atf 1, filter, filter gasket, extra bolts (NO PAN GASKET, $12 at oreilly), also comes with hand pump and also my ghetto gravity filler with about 2L of extra fluid in it.
$100
Brand new Outer Axle joint, new oem, just the joint no boot no grease
$20
Secondary air pumps
$40 each
early B5 sunroof motor
$50
crank and PS pullies V6 and 2.7t
$20 each
v6/2.7t cam pullies
$20 each
Reply
