Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 16 to 30 of 32
  1. #16
    Warren, MI
    50mpg double wishbone
    I want to, or to use some Mk1 buckets cuz they're pretty compact/square, but I have no welder so anything I do has to be bolted in using steel bar or something.
    If I can buy a set of lights or buckets and anyone's willing to help me fab them or get them in I'll buy you beer or lunch or whatever, OBO.
    Quote Originally Posted by sprstu View Post
    and mesmerizing. Ive never considered how much those balls move about until now.
  2. #17
    May 2011
    St. Cloud, MN
    337, '98 Jetta GLX
    What about 4th Gen Camaro buckets?
    Quote Originally Posted by 9jetta6 View Post
    Oh dang it does look like its chopped in the back there. Clicked on the link, if its actually legit and can run good, looks fun.
  3. #18
    Warren, MI
    They look kinda deep. Could work though if I chop the front off to match the Anal Probe.
  4. #19
    Jun 2010
    Hudson, WI
    04 A4 USP
    Quote Originally Posted by Sven7 View Post
    I haz welder u can uze. I might need to get the tank refilled but that is no biggie.
    Quote Originally Posted by bowls
    Who has/can refer me to someone with a lift that is bored and wants to get smoked up?
  5. #20
    Jan 2011
    smpls
    03 GTI
    just for reference how much space do you actually have to work with?
  6. #21
    Oct 2010
    Becker
    Essten, Fat Chick Project
    Maybe some super bright fog lights?
  7. #22
    Warren, MI
    ~ 10 wide 6 long 4 deep. A little bigger and smaller in each dimension depending on angles.
    Jigs, I can't weld
    Fogs? I'm trying to keep it somewhat legal.
  8. #23
    Oct 2008
    Crystal
    82 Rabbit
    Jigs, I can't weld
    You know where I am, I can weld if it doesn't have to look pretty. I might even have some metal stock here that would work. Hell, I think I might have some plexy too. You can bend it with a heat gun and something to let it fall to shape on.
    Think of it as a consumer tax for sucking at driving.
  9. #24
    Warren, MI
    Sounds great, Shane! I'd like to meet up with Jigs anyway because he's a lot closer but will keep it in mind
    Next stop, a junkyard.
  10. #25
    MK1 Caddy
    I like Glen's idea with projectors. You can't get much more compact than that. Plus a decent projector with a decent bulb is going to give you 10X the light you ever had with the original probe lights.
    Quote Originally Posted by palmer View Post
    Teach a man to fish, and he will shut trannys up all day.
  11. #26
    Warren, MI
    What kind of cost are we looking at for projectors? Honestly if it's not a direct swap, I'm also going to need a lot of help with it. I'm inexperienced and know little about electrical stuff.
    Pics of headlight area.
  12. #27
    Warren, MI
  13. #28
    Oct 2008
    Crystal
    82 Rabbit
    Aerodynamics fail. Stay on target.
  14. #29
    Warren, MI
    Honestly they're doing a lot better than the stock ones in up position.
    However, if that guy only had to trim the hood a little for that, couldn't I get a "normal" flush fit fixed conversion for an S13 and fit it in there?
  15. #30
    Oct 2008
    Crystal
    82 Rabbit
    Probably. You could also just match the curve by sanding a block of wood and heat forming plexy over it. Make your own, perfect fit. If you're too squeamish to make your own, I can probably make you a set for a small fee since I will be using up some materials I have.
  1. Replies: 0
    Last Post: 07-29-2012, 09:26 PM
  2. Conversion Advice
    By Cspence024 in forum Technical
    Last Post: 04-24-2010, 05:05 PM
  3. E30 5-lug conversion?
    By JTapper in forum Technical
    Last Post: 11-17-2009, 07:52 PM
  4. HID conversion ?'s
    By Fearnside in forum Euro Automotive Discussion
    Last Post: 11-16-2009, 04:06 PM
  5. 16v conversion kits???
    By Eyedeas in forum Euro Automotive Discussion
    Last Post: 10-28-2008, 06:02 PM
