Results 1 to 10 of 10
    Silver Creek
    GTI's
    Default Another CEL code
    Unfortunately I only have access to an OBDII scanner and not a Vag-Com. The code is P0100 Mass or volume air flow circuit malfunction. Could this be due to a dirty MAF sensor?
    Jan 2008
    Aftermarket or stock intake?
    Silver Creek
    GTI's
    I have the Carbonio intake that untilizes the stock airbox on the engine. Looks like the picture below.
    Jan 2008
    could be bad MAF or bad harness?
    Silver Creek
    GTI's
    Ah, good information. Thank you. I will take a closer look at that tonight.
    Silver Creek
    GTI's
    Quote Originally Posted by magilson View Post
    magilson, you must be psychic!
    Jan 2008
    Quote Originally Posted by 97GreenTI View Post
    Glad you found the issue!
    Silver Creek
    GTI's
    What can I safely clean the MAF with? Can I use any ol' MAF cleaner from the parts store?
    Jan 2008
    MAF cleaner from CFC or equivalent. Do not wipe off or try to mechanically clean it. Just let it dry and put it back in service.
    Silver Creek
    GTI's
    Thank you!
  1. 12v VR6 code
    By jonnyblayz in forum Technical
    Last Post: 06-06-2012, 11:29 AM
  2. P0322 code help
    By TqMonster in forum Technical
    Last Post: 05-04-2012, 08:30 PM
  3. Tapping and Code
    By MisdemeanorMatt in forum Technical
    Last Post: 10-12-2011, 11:59 AM
  4. code help
    By terrance roush in forum Technical
    Last Post: 09-26-2010, 02:03 PM
