Results 1 to 12 of 12
    Mound
    72 911T, 1980 Golf, 300D
    Default a1 short shifter
    Given the "cutting shifter" posts and all that, I felt I had to take some type of leap.
    Take 1 stock shifter lever. And two chunks of metal, same thickness, about 1.5" long each
    (No, I don't measure... Did this all by eye... rulers are no fun..)
    Chop that chunk about somewhere in the middle.
    Weld the two plates to it about 1/2" or 5/8" longer or so... again, no ruler..
    Install that chunk o ugly weld into your 020 trans... and..
    Yup, its a real short shifter folks. My shift throw went from 5.6" at the top of the shifter, down to 4"...
    "Being powerful is like being a lady. If you have to tell people you are, you aren’t. " - M. Thatcher
    Mound
    also note that mkIII weighted shifter bar as well, as it fits the linkage. it helps out the feel quite a bit.
    Jul 2007
    Duluth
    a2, e39
    so you did this? from danjreed's tips? cool. I ended up just buying the damn thing.
    -Pete flickr
    Warren, MI
    50mpg double wishbone
    so let me get this straight... it looks like you made the lever longer. To shorten shifting?
    Quote Originally Posted by sprstu View Post
    and mesmerizing. Ive never considered how much those balls move about until now.
    Warren, MI
    so it looks like you lenghtened the lever. Is that right? It's hard to tell...
    Mound
    yes you lengthen it so you move the lever farther with the same effort you used previously.
    Sep 2007
    duluth
    old passat wagon.
    Yes. By lengthening the lever, it shortens the throw.
    I did it to my car, only I welded one piece on to the end, ground it down, and drilled a few extra holes for various settings.
    Quote Originally Posted by Driv3r View Post
    Look man don't start talking shit!
    Aug 2006
    St. Paul
    the toilet
    I need to weight my shifter bar.
    Apr 2008
    Mason City, IA 50401
    '91 Golf TD
    Nice upgrade.
    While we are talking about cheap shifter upgrades,...
    See that white block below your new lever?
    I was putting some new bearings in my alternator, trying to get rid of the goat under my hood, the old bearing fit perfectly over the shaft and tightly into cage.
    So instead of the white block, I have a (used) sealed bearing.
    Side note:
    Alternator runs smoothly,.. but the goat remains.
    Could be hiding in the power steering pump.
    Nov 2005
    St micheal, Mn
    2011 Jetta Sportwagen TDI
    Pics are for a MK2 car.
    A easier route would be to get a extra one at the junk yard and use it to lengthen the shifter. This way you only weld once and the stock hole is still there. so you could revert to stock in a flash. I have done it that way for years.
    The MK3 shift wieght works on the MK2 cars not a MK1. For those take your stock rod and weld a 3 inch 1.5 inch steel rod to it. Works great. Again Been doing them that way since I first saw the MK3 style wieght.
    Chad Erickson
    SCI Performance
    612-722-8897
    Chad@sciperformance.com
    http://www.eurowerks.org/image.php?u=316&type=sigpic&dateline=1195628404
    Apr 2008
    Locash
    One of 5071
    Thats not Buffum approved
    "there was one"
    Mar 2010
    chevrolet
    cool great post.
  1. Forza 2 Challenge
    By Digital K in forum Euro Automotive Discussion
    Last Post: 05-13-2008, 10:20 AM
  2. short runner vr6 manifolds
    By tima in forum Euro Automotive Discussion
    Last Post: 01-23-2008, 09:07 AM
  3. For Sale: Evolution Motorsport Short Cold Air Intake...Like New!
    By kenestra in forum VW-Audi Car Classifieds
    Last Post: 11-08-2007, 03:28 AM
  4. Short Video compilation i made
    By SLK in forum Euro Automotive Discussion
    Last Post: 07-20-2007, 05:46 PM
  5. My R8 Experience (22 Pics + Short Video!!!)
    By CaRJoE0220 in forum Euro Automotive Discussion
    Last Post: 05-24-2007, 07:19 PM
